Results 1 to 10 of 14
Thread: emissions failed
    manchester
    Default emissions failed
    emissions failed on my mot test it was 3% over any ideas, had a new high pressure fuel pump fitted 8 weeks ago,tried fuel adds,not worked cheers rick
    Are you VXR Enough
    13 Post(s)
    Engine : 6.0 V8 Thunder
    if ya let us have a few more details like what engine you have etc we might be able to help ya bud
    Regular Member Celes's Avatar
    Slovenia, Koper
    Vehicle : Opel Signum
    Trim : Sport
    Engine : 3.0 CDTI
    Year : 12/03
    2.2Direct I believe
    South Wales Assistant Regional Organiser davidjameswest's Avatar
    llantwit major
    poss new cat them my friend
    WGAF#5
    rick - do you do long or short runs >>>
    my advice would be to put a tin of fuel treatment in the motor and take it for a long run until its good and hot - then get it in for the emissions test whilst its still hot - 3% should be cleared by this
    then it will give you another years ticket to sit down and resolve the issue properly
    Regular Member Readster's Avatar
    Plymouth
    A long hard run & fuel cleaner will do the trick.
    I was advised to give the Vec & Mrs R's diesel Golf a 'clear out' before the MOT
    Hope this helps
    John
    manchester
    i do a lot of miles(taxi) so put fuel adds,took it for a long 95mph(on a private road lol) took it back to taxi test station,passed.many thanks for the help as always from you lot on here cheers rick
    Regular Member si_hoss's Avatar
    Apr 2009
    Stevenage, Herts
    Quote Originally Posted by rick1965 View Post
    On our diesels my brother and I always changed the air filter night before, give it some grief to blast out any black smoke and MAKE SURE the engines up to temp when giving it to the MOT guy. Always works and been doing it since owning a 1993 1.5TD Nova back in the day!!!
    Plymouth
    Great, glad you are sorted matey
    Ashington, Northumberland
    Quote Originally Posted by si_hoss View Post
    ......... and MAKE SURE the engines up to temp when giving it to the MOT guy......
    The tester should not do a smoke test until the car is at operating temperature anyway. The oil temperature should be measured and should be 85 degrees plus before carrying out a test, otherwise there is a possibility it will fail. The first thing I do is the smoke test because the engine is nice and hot as the presenter has just drove the car there.
  1. Failed MOT due to emissions
    By johnnylegs in forum Vectra C / Signum Troubleshooting
    Last Post: 20th June 2011, 20:50
  2. Failed mot on emissions
    By G4GAV in forum The 'Off Topic' room
    Last Post: 9th March 2011, 21:21
  3. 2.2 direct failed mot on emissions,
    By clive3373 in forum Engine & Drivetrain
    Last Post: 5th May 2010, 06:30
  4. Emissions
    By sb1uk in forum Engine & Drivetrain
    Last Post: 10th April 2009, 12:41
  5. Failed MOT on emissions
    By simac in forum Vectra C / Signum Car Chat
    Last Post: 18th June 2008, 19:44
