Results 1 to 10 of 11
Thread: engine managment light
    Aug 2009
    bridlington
    Default engine managment light
    hi is there anyway i turn engine managment light off myself
    Aug 2009
    bridlington
    2005 cdti 120
    Regular Member John C S's Avatar
    May 2007
    Gangsta crossover on the drive? Check
    Disconnect the battery on the negative side for 1/2 hour. This will do a reset.
    If the fault reoccurs, the light will come back on, in which case, you need to get the fault code read with a reader or via the Tech-2 system in a VX dealer, which will cost you.
    Aug 2009
    bridlington
    thanks for reply code is p1125 air intake??????
    Regular Member m1ke823146's Avatar
    Aug 2009
    derby
    check all vacuum/air pipes for splits/leaks including boost hose/s and intercooler hoses, on mine the problem was a small vacuum hose (hard plastic hose3-5mm in diameter) that was routed under the top engine cover, it was rubbing on the cover and wore a hole in the pipe, hope this helps?
    mike
    slough
    [quote=pjabrid;1061116]hi is there anyway i turn engine managment light off myself
    is this light engine managment or service light?
    Regular Member rushy's Avatar
    Vehicle : 9-3 Wagon
    Trim : Turbo Edition
    Engine : TID (1.9 16v)
    Year : 2010
    Mileage : 137000
    [quote=hippo;1068492]
    Quote Originally Posted by pjabrid View Post
    EML, hence the fault code.............
    11 Post(s)
    Yes, once the fault has been fixed, it will self extinguish.
    Usually switching the car off for at least one hour is enough
    If it is still on after restarting one hour later then it is a permanent fault and requires urgent attention
    It sounds like the MAF sensor may be on its way out
    If your car is under warranty then get it to a VX dealership for code reading and claim
    If your warranty has expired then wait until it appears more often
    Quite often it can be near failure, but can stil last a few months!
    Aug 2009
    bridlington
    vx are telling me its the throttle body £231 job done or am i been done
  1. Engine Managment Light Help
    By Telboy in forum Vectra C / Signum Car Chat
    Last Post: 5th July 2011, 00:10
  2. engine managment light
    By patch22 in forum Engine & Drivetrain
    Last Post: 22nd June 2011, 22:52
  3. Engine Managment Light
    By zealot210 in forum Vectra C / Signum Troubleshooting
    Last Post: 30th June 2010, 11:58
  4. Engine Managment Light, Help!!!!
    By whatthevecisup in forum Electrical & ICE (including SatNav)
    Last Post: 12th April 2008, 22:29
  5. engine managment light?
    By tonytaxi in forum Electrical & ICE (including SatNav)
    Last Post: 20th June 2007, 07:38
