Originally Posted by
hyperman
if you're getting a bench then your gonna need some more weights, get a couple of 10kg, a couple of 20kg, and possibly a couple of 15kg weights, even if your not going to get into heavy lifting these will make thing a lot easier for you rather than having to add all the weights you currently have. and if your just starting out my advice would be to take it easy for the first month of lifting, getting used to the weights without killing yourself, lift what feels comfortable to you and only straining on the last couple of reps on each set, try to keep a nice uniform movement on every rep you do. then after about a month start to increase the amount of weight you lift pushing yourself further and keep increasing when you can...
hth
