Thread: K and N service kit......
    Regular Member david.aka.judas's Avatar
    Suffolk
    Default K and N service kit......
    Am I better of getting the aerosol spray oil or the non aerosol oil.
    which is better or doesn't it matter?
    cheers if you can help
    The world famous city ground
    Vehicle : Vectra cdti estate
    Trim : Get a
    Engine : Dirty diesel
    i have a 2 part kit that is about a tenner.....
    this contain's the cleaner and non aerosol oil that i find easier to use as it has level's on the oil for the amount you need, if you over oil it will naff up the maff sensor
    Midlands Mod Shop - NFFC.
    Ashington, Northumberland
    I'll go with Rich on the non aerosol, simply for the reason he says, it has marks to show you how much to use
    Regular Member ANDY W's Avatar
    May 2007
    WINSFORD
    I have a service kit aswell but my oil is the spray type which I find easy enough to use as you spray light coats untill the filter is red all the way through and allow time for the oil to penetrate through. Just in case I did over oil I patted lightly with kitchen towel to remove any serious excess.
    I did this in January of this year and have had no problems.
    Also when you remove the filter from the airbox be sure to clear all the debris from the bottom of the airbox and tap the filter with the dirty side down as loads of crud gets trapped in between the pleats / veins.
    As to whick kit is best I really dont know but you use far more cleaning solution than oil so maybe get a big can of cleaner as I nearly used all mine up on the first clean so not much left for next time.
  1. Replies: 341
    Last Post: 20th April 2016, 06:29
  2. Service book - copy of service page (2.0 DTi)?
    By mvdg in forum Vectra C / Signum Car Chat
    Last Post: 25th February 2011, 22:48
  3. Free MOT & Service reminder service
    By norfolk in forum Vectra C / Signum Car Chat
    Last Post: 1st July 2010, 05:59
  4. 40k mile service and service light
    By a_j_mair in forum Vectra C / Signum Car Chat
    Last Post: 31st January 2009, 14:41
  5. is there a way to reset service light yourself after a service?
    By EURO G in forum Vectra C / Signum Car Chat
    Last Post: 5th January 2008, 00:14
