Thanks Thanks:  4
Likes Likes:  60
Page 3 of 22 FirstFirst 1234513 ... LastLast
Results 21 to 30 of 213
Thread: Vectra Estate from Romania (E.U.)
  1. #21
    Regular Member CristianTM's Avatar
    ROMANIA, Eastern Europe
    Very nice car and very good modification !
    CristianTM.
    Romanian: Din ce oras esti ?
  2. #22
    Regular Member turbohaggis's Avatar
    Scotland (twinned with Libya)
    nice car and some good mods going on there, keep up the good work fella
  3. #23
    Regular Member Lao's Avatar
    Aug 2009
    Romania, E.U.
    Vehicle : Vectra C Estate Automatic
    Trim : Elegance
    Quote Originally Posted by CristianTM View Post
    CristianTM.
    Thank you all for all your nice messages. Cristi, I'm from Craiova and I'm also a clubopel.com member. Here's my topic from over there.
    Last night I finished mounting the door trims, which took me almost 2,5 hours. They are very hard to remove and reinstall. I just used some universal silicone and a few pop-rivets to hold them still while the silicone acts. Now they are looking nice fitted in the car. Pics:
    1. Tool used to crash the back door trim's pin.
    2. Crashing/removing the back of the door trim's pin.
    3. Inserting the rivets.
    4. Final product.
    Before:
    After:
  4. #24
    Regular Member John C S's Avatar
    May 2007
    Gangsta crossover on the drive? Check
    Much better than the Wood.
    that's how it should look!
  5. #25
    Aug 2009
    Romania, E.U.
    Trim : Elegance
    Well, my attempt to repair the known swirl valve problem didn't work, so now I just bought a new inlet manifold from ebay UK and I'm looking for the cheapest swirl valve motor (actuator) that I can find (possibly with your help).
    If anyone knows a good price, let me know.
  6. #26
    Aug 2009
    Romania, E.U.
    Trim : Elegance
    Quick qustion: should I or shouldn't I make the black strip? Now it's only Photoshop.
  7. #27
    Aug 2009
    Romania, E.U.
    Trim : Elegance
    Anyone know where I can find a motor (P/N: 13192013)for my recirculation flaps? I have a toothed wheel that has 2 teeth missing.
    Here you can see the 2 teeth that are missing on the little white wheel:
    And here's the wheel:
  8. #28
    Regular Member kenp's Avatar
    Kr. Hyllinge, Denmark
    Vehicle : Insignia
    Trim : Dynamic
    Engine : 1.6 turbo
    Year : 2019
    Mileage : 44000
    The dealers mate or this seller in the UK http://www.partsreunited.co.uk/index.php?a=2&b=18386
    (the same part is used in Saab)
  9. #29
    Aug 2009
    Romania, E.U.
    Trim : Elegance
    I'm waiting some answers from 2 eBay sellers. Thanks.
  10. #30
    Aug 2009
    Romania, E.U.
    Trim : Elegance
    Today I changed the inlet manifold and the timing kit, includin water pump. Although it wasn't specified anywhere in the service book, I think it was changed before, because one of the tensioners was a SKF. The rest of them I think were original from Opel. The timing belt looks worst in the pics than in reality:
    The old manifold looked like crap, both the valves and the mug that was inside of it. The mechanic assured me it wasn't a dirty engine:
    Interior of the inlet manifold:
    I stick to my previous opinion that the swirl valves actuator doesn't need to be changed, because the valves' motion is the same for all the manifolds:
    Maybe someone can tell me where this plug is from. It's unused and it's located near the timing belt cover, towards the injection pump area.
    And the final result:
    As duration, it all took 6 hours and the mechanics worked miracles.
    Hard stuff:
    1. Removing the injection pump pulley:
    2. Removing the plate on which the gas separator sits. This took aprox. 30-40 minutes, only because the mechanics didn't work on a Z19DTH before. On the second engine I'm sure they will remove it in 10 minutes (assuming someone else is mad enough like I was to change the inlet manifold):
    The rest was just uninstalling and installing, which took most of the time. The inlet manifold was replaced in 10-15 minutes, but the "getting to it" was pretty time consuming. We mounted the actuator on the manifold before it was placed back on the car. It was easier this way.
    All working good now and I'm very happy with it.
    Next thing to be replaced is the valve body in my AF40-6 speed gearbox.
  1. Vectra C from Romania
    By Bolo_BDC in forum Introduce yourself.
    Last Post: 21st October 2020, 11:48
  2. Hi everybody!!! Im Adrian from Romania
    By adriano872 in forum Introduce yourself.
    Last Post: 3rd June 2011, 05:06
  3. Vectra Estate Voted Top Used Estate in What Car 2010
    By keefy*2010 in forum General Chat
    Last Post: 22nd October 2010, 15:54
  4. Hello from Romania
    By theo in forum Introduce yourself.
    Last Post: 7th November 2007, 00:14
  5. Hi. Alex from Romania here.
    By 2 Bad in forum Introduce yourself.
    Last Post: 27th February 2007, 23:51
https:www.vectra-c.comforumshowthread.php91937-Vectra-Estate-from-Romania-(E-U-)&goto=newpost
opel vectra rear camber adjustment
