Results 1 to 3 of 3
Thread: Fault on Steering Angle Sensor c1531
    Southampton
    Default Fault on Steering Angle Sensor c1531
    Steering wheel Warning light on, heavy steering
    Read the threads on fluid top up - not really got time to crawl about removing trim so took it into Vx for tech 2 just in case
    Fault code 1531 - steering angle sensor voltage high, leads to 1526 Steering motor not operating
    Solution - New CIM 430 - OW ! ( i was hoping they'd just top fluid up and that would cure it :-(
    So bearing in mind this is the same dealer that wanted 300 plus to change boost pressure and mass flow senors on the turbo when a pin hole in a 50p tube was causing the fault I thought id ask for some help !
    obviosuly the fault code isnt a low fluid issue - but is it worth taking the arch liner / bumber off to check it anyway (damned if i can see the level from the ground) ?
    is the steering angle sensor accessible ? can it be replaced ? One thread suggested cleaning connector pins by the pump - is this where the sensor is located or is it on the steering mechanism
    or a CIM from a breaker ? (in which case wouldnt it have to be set up by a Vx dealer ?)
    Or do I have to bite the bullet ?
    opinions appreciated guys
    phil.
    2003 2.2 Dti 140k
    Regular Member steve's Avatar
    Nov 2007
    Ashington, Northumberland
    Southampton
    Default strange
    Bit odd this, having read other threads about steering wheel warning I bit the bullet, took the bumper off and topped up the power steering fluid which was down to min
    Test drive shows power steering present (notice the difference :-)
    Still got the fault light - might do the battery trick to try and get rid of that
    Dont understand how low fluid might cause the steering angle sensor to give a high reading though (as that was the tech 2 fault code)
    strange stuff
    but thanks to the How2 contibutors once again
    cheers
    phil
  1. Steering angle sensor
    By RichM in forum Electrical & ICE (including SatNav)
    Last Post: 11th November 2012, 20:22
  2. Steering angle sensor
    By Gregiboy in forum Suspension, Wheels & Brakes
    Last Post: 1st April 2012, 14:11
  3. Steering angle sensor
    By 1979john in forum Vectra C / Signum Troubleshooting
    Last Post: 16th August 2011, 20:24
  4. Steering Angle Sensor
    By r.bailey63 in forum Suspension, Wheels & Brakes
    Last Post: 25th July 2009, 14:48
  5. Steering Angle Sensor
    By chanito in forum Electrical & ICE (including SatNav)
    Last Post: 1st August 2007, 18:12
Opel C1531
Opel DTC C1531-0B
vectra c 2.2 steering angle senser
vectra c1531
opel vectra c błąd c1531
c1531
