Results 1 to 3 of 3
Thread: spanner light on my Signum 2.0DTI..help pls
    Sep 2009
    Gateshead
    Vehicle : Vectra C Estate
    Trim : Sri
    Engine : 1.8i VVT
    Mileage : 64000
    Default spanner light on my Signum 2.0DTI..help pls
    Hello all,
    have got problem with spaner light.. this light has been playing with me since i bought the car a mounth ago(no warranty(what a stupid step(.. When the light goes on the car is loosing power when light goes off everything is ok(the longest good run was for 4 days).
    i took car to the 2 garages for diagnostic but they could not find any faults and told me to go to the Vauxhall dealer for diagnostic.
    at vauxhall they put in on comp. and here are results:
    CHECK AND REPORT EML ON,CARRY OUT TECH 2 TEST,2 TC STORED THOTTLE CONTROL CIRCUIT FAULT
    vauxhall would charge me 120pounds to fix this problem they didnt not give me any fault codes just that text above
    any advices plss(as should i clean egr???)
    Thanks very much
    middlesbrough
    SAME HERE The spanner light comes on cuts out or sounds like it is running on 2 pots.
    Happens completely at random I turn it off and on till it starts as normal
    dose this two or 3 times a day,
    some time it will not start so I had to pull the a vacuum pipe out,
    And put in to limp mode to start it at last i can get where i am going.
    Had the fault readers on it and
    no fault shown each time even when it waS happening.
    EGR has been off and cleaned still the same?????
    Vehicle : Signum 2.0 DTi
    Trim : Elegance/Elite
    Engine : 2.0DTi
    Mileage : 73350
    Take the boost sensor off and give it a clean with carb cleaner
    and still loving it
  1. Car Spanner Light 2.0dti
    By holtie in forum Engine & Drivetrain
    Last Post: 17th January 2013, 16:37
  2. Spanner through Car warning light - 2.0DTi
    By Led in forum Vectra C / Signum Car Chat
    Last Post: 26th January 2011, 18:11
  3. help! spanner light! 2.0dti
    By mick p in forum Engine & Drivetrain
    Last Post: 12th December 2010, 18:38
  4. Signum 2.0DTI - spanner light - 3rd time in 6mths
    By busterpoo in forum Engine & Drivetrain
    Last Post: 19th May 2009, 17:37
  5. Signum 2.0DTI spanner light
    By signum_boy in forum Engine & Drivetrain
    Last Post: 17th May 2007, 22:00
