Results 1 to 10 of 20
Thread: EGR cleaned but..
    Default EGR cleaned but..
    Hi guys,
    The car suddenly lost power and wouldnt rev pass 2000 rpm, had the fault codes read out giving p0400.
    That seems to point to the EGR valve.. i took it off, cleaned it as per the how 2, put it back in hoping bobs my uncle but hes not ! still the same fault & fault code.. maybe i didnt clean it right..
    Is it possible it could be the MAF sensor? i mean p0400 code is abit vague... please guys any ideas? this is driving me nuts!
    p.s. a new replacement egr valve on the 2.0 dti is a complete rip off.. £220 ++!!! the 1.9 cdti is half than that!
    Full Member spennny's Avatar
    Blantyre
    Have a look here mate, seems to have similar issues, 5th / 6th post down points to the MAF sensor
    http://www.cavweb-forums.co.uk/showthread.php?t=41554
    Hope its of use
    hi mate,
    Thanks for your reply. but i think i can disregard the MAF sensor.
    I disconected the air hose from the MAF sensor and turned the car on... the problem is still the same so i can assume its not the MAF sensor.. ?
    Blantyre
    Diesel blokes will be along soon mate to sort you out
    nice1, im waiting twiddling my thumbs lol
    If someone could answer this for me.. is it ok for me to disconect the EGR valve and then turn the car on.. if the car revs high i can conclude its not the EGR valve? Thanks in advanced..
    Vehicle : Signum 2.0 DTi
    Trim : Elegance/Elite
    Engine : 2.0DTi
    Mileage : 73350
    Check your vacuum hoses for leaks or perished connectors (very common) check your vacuum hoses are connected up properly .
    Whilest checking test the system for suction the system works on a 0.6 bar vacuum just detectable with a wet finger if no vacuum detected suspect hose splits or actuattor/s going faulty.
    Also check your manifold hoses for splits especially the hose that goes down to the intercooler .
    and still loving it
    Birmingham
    Quote Originally Posted by spennny View Post
    Hope its of use
    Haha, that above post is mine!! Deffo check the Vacuum hoses and leak of pipes. BUT if the car was running fine prior to doing this, it points to the vac hoses as they are very very common!! Check for splits on the underside. These are small pipes near the battery area and bulkhead by the brake servo! let us know how you get on.
    Bye bye Vec B
    - Hello Siggy!
    Thanks for the replies guys!
    incidentally i am a member of both RAC and The AA, both have checked the pipes ( roughly), but i dont have a clue if they checked them for leaks..
    ok maybe a dumb question, but how would i check for splits, i mean are these clearly visible unlike the leak off pipes where they cannot be seen by the eye?
    i havent a clue how to test the system for suction..
    oh and by the way to test if it is indeed the EGR valve, would disconnecting it and running the car be ok to test it?
    Regular Member steve's Avatar
    Nov 2007
    Ashington, Northumberland
    Did you clean the egr valve and inlet or just egr valve.... maybe its blocked before it hits the egr valve..... if you take engine cover off you have 6 (i think) star bolts holding top of inlet on at the bottom right hand side of the cover. Take that top off and check for carbon build up in there
    might be worth a look too http://www.vectra-c.com/forum/showth...ght=boost+hose
    i cleaned the EGR and outer inlet i.e. the part just above the egr valve and oh my days that was clogged up to the max... i mean i scraped of huge amounts of carbon, all in all it was enough to fully fill a standard size cup!!!
    i didnt clean the hole manifold though.. didnt think that was needed?
  1. cleaned the old and the new!!!!!!
    By j1 wyx in forum Quick Photo Album
    Last Post: 22nd November 2010, 08:27
  2. All cleaned out!
    By multi in forum Quick Photo Album
    Last Post: 8th June 2009, 11:02
  3. all cleaned for pvs
    By happypostie in forum Detailing and Car Care Discussion
    Last Post: 7th June 2009, 21:53
  4. cleaned the vxr
    By biglee55 in forum Quick Photo Album
    Last Post: 19th May 2009, 21:38
  5. Cleaned the VXR
    By BigP in forum Gallery
    Last Post: 29th April 2009, 21:43
