Thread: 150 cdti auto engine and gearbox software
    Sep 2009
    St Albans Herts
    Default 150 cdti auto engine and gearbox software
    I have only had the car a couple of weeks , when i bought it I never noticed the jerk when its put into drive (especcially after reverse) or the jerk when it changes down from 5 to 4, nothing seriuos but annoying,
    with this forums help I changes the gearbox oil which wasn't burnt or smelly but no real difference, so after further reading on this forum I went to STA auto gearbox's in Aylesbury yesterday who gave it a test drive where it performed near enough faultlessly, he suggested gearbox is ouk but I could do with checking car has the latest software for the gearbox and ecu as this may sort it out.
    does anyone know any independants who could do this as I am not keen on going to a vx dealer? or has anyone had this done?
    I am in St Albans herts and don't mind travelling
    Regular Member Lao's Avatar
    Aug 2009
    Romania, E.U.
    Vehicle : Vectra C Estate Automatic
    Trim : Elegance
    Mine behaves the same, only I didn't change the oil yet.
    Sep 2009
    Telford
    Default Barrybowe
    I own a 1.9 CDTI Sri estate six speed auto. My gearbox has a problem only when warmed up after 30 miles or so. It either jumps into neutral or bangs into gear on the 3rd to 4th change only.
    I have changed the rad/oil cooler and oil this helped for a short while. I then had oil changed again this again helped for a short while but I still have the problem does anyone know if this si the mechanics of the gearbox or the ECU or electronic switching that is causing the problem.
    I am able to drive it in the manual shift mode if I change up to fourthas quick and smooth as possible.
    If the gearbox needs a rebuild does anyone know of a good (reasonably priced) mechanc who can do this. Or is anyone in the know to a good second hand gearbox.
    Barry Bowe.
    Sep 2009
    St Albans Herts
    the Guy at STA said that there are a lot of vauxhall vectras running around that would benefit from software upgrades (downloaded from vauxhall) that clear problems as vauxhall have learnt to clear the problems by changing the parameters in the controlling ecu's so that seems to be the first port of call before any rebuilds or gearbox work.
    Sep 2009
    St Albans Herts
    Quote Originally Posted by Barrybowe View Post
    Barry Bowe.
    do you have any warning lights?
    Sep 2009
    St Albans Herts
    i will try and write a "how to" for changing the gearbox fluid when I'm at work tonite
    Aug 2009
    Romania, E.U.
    Trim : Elegance
    Will look into it with interest.
  1. 1.9 cdti auto, conversion to man gearbox
    By ricky1 in forum Vectra C / Signum Car Chat
    Last Post: 25th October 2010, 00:02
  2. v6 cdti auto gearbox sensor
    By porkaboy in forum Engine & Drivetrain
    Last Post: 2nd October 2010, 11:25
  3. Gearbox oil for CDTi 150 auto ??
    By Signumcdti in forum Engine & Drivetrain
    Last Post: 27th June 2010, 21:59
  4. 3.0 v6 cdti 20005 auto gearbox problem
    By nte01 in forum Engine & Drivetrain
    Last Post: 22nd March 2009, 02:06
  5. Auto Gearbox Software
    By Curly7 in forum Engine & Drivetrain
    Last Post: 13th August 2008, 09:43
