Thanks Thanks:  1
Thread: V6 2.8 cold start revs
    Regular Member Largespanners's Avatar
    Jul 2009
    Swindon
    Default V6 2.8 cold start revs
    Hi All,
    Got a question for you.
    I'm enjoying my 2007 2.8 Elite Automatic, it's the first V6 i've ever had, the first Turbo i've ever had and also the first Automatic i've ever had.
    Previous car was a 2.2 Elegance and when i started it from cold, the cold start would keep the revs at just about 1,200 rpm or so.
    When i start my v6, the revs shoot straight to 1,600 rpm and stay there for about 20 seconds before gradually coming down to about 1,100.
    If i don't wait the 20 secs before engaging drive, i get a Thud through the body as Drive is engaged. If i wait the 20 seconds before engaging drive it's all ok. As soon as drive is selected, the revs drop down.
    When she's warm, she settles at about 700rpm ish so that's all fine.
    Just seemed a little extreme for a cold engine to shoot up so high, but i guess emissions are to blame.
    Hopefully someone with a little more V6 experience can put my mind at rest?
    Ian
  2. Thanks MikeElite thanked for this post
  3. #2
    Jul 2009
    sussex
    1600 is way to high. as you say it should be 1200ish or maybe even less.
    not sure if you have an idle control valve on that engine... but if you did it might need a clean.
  4. #3
    Jan 2006
    Norfolk
    My 2006 2.8 Elite starts off high as well, I don't think its uncommon mine drops quickly also, will check if its 1600 ish when I next start from cold.
  5. #4
    Jul 2009
    lanark
    i work in a dealer and was just on the insignia course a few month back and that is perfect behavior, all 2.8's do it
  6. #5
    Regular Member BigP's Avatar
    Apr 2006
    Heated, Electric Recaro Leather
    Normal for them to rev that high from a cold start. I believe its called fast idle and normally drops down a bit within about 20 secs. Caught me out a bit when the VXR did it the first time too.
  7. #6
    Regular Member LOCKSTOCK's Avatar
    SUFFOLK
    Yes mine does that as well, i think its all normal and nothing to worry about.
  8. #7
    Ashington, Northumberland
    Same here, high revs for 20 or so seconds. Normal cold start procedure
  9. #8
    Full Member watchman's Avatar
    Apr 2009
    Leeds
    Mileage : 56000
    My 2.8 does this as well.
    I've being meaning to ask this question myself.
    Thanks for the help.
    2.8T Signum Design
    Teapot TUNED
  10. #9
    Jul 2009
    Swindon
    Guys, thanks for the response i really appreciate you putting my mind at rest.
    Glad to see we were kinda thinking the same thing :-)
    Ian
  11. #10
    Dec 2005
    lincs
    Hi i have a 2.8 T too and it did the same on startup when i first got it, But can anybody tell me how to solve a problem i have now... when i start it up you have to leave it idling for about a 2 min or so otherwise if you rev it, it runs like a bag of nails and stalls then when you start it up again its ok. I seem to have had this problem ever since my battery went flat and i tryed to start it.... do i need to disconnect the battery for the management system to reset it's self again? or is there something more that i need to look at PLEASE PLEASE HELP
  1. smoke at cold cold start
    By azacbr6 in forum Engine & Drivetrain
    Last Post: 5th December 2012, 18:23
  2. Erratic revs on start & EML on under load.
    By paz_badboy4life in forum Engine & Drivetrain
    Last Post: 26th August 2012, 16:55
  3. engine revs dropping when cold 03 2.2DTI
    By stuartcorbitt in forum Engine & Drivetrain
    Last Post: 7th July 2011, 18:15
  4. 01 Vec B 2.2dti cold start no revs!
    By tommoturbo in forum Engine & Drivetrain
    Last Post: 31st January 2008, 05:41
  5. Revs surging on cold start
    By j13hdb in forum Vectra C / Signum Car Chat
    Last Post: 4th November 2007, 20:55
