Thread: DPF or not?
    Full Member Lao's Avatar
    Aug 2009
    Romania, E.U.
    Vehicle : Vectra C Estate Automatic
    Trim : Elegance
    Default DPF or not?
    Hi all!
    I was wondering if this is the DPF or not and I thought it'd be better to ask the specialists. What do you think? It sits right in the middle of the car and from what I've heard, if it has something coming out of it, it must be the DPF.
    yes thats it
    Aug 2009
    Romania, E.U.
    Trim : Elegance
    Thanks, I was thinking the same. Any suggestion on how I can clean it, other than with a computer?
    A local mechanic told me to constantly run the car at 2500 rpm for 25 minutes. This way he says, the ECU will enter the DPF cleaning program and the DPF will clean big time. Is this true?
    preston
    Yes thats the dpf with the fuel line going into it which injects diesel into the exhaust to burn all the deposits collected at high temp.
    Quote Originally Posted by Lao View Post
    Yep take it for a run somewhere. Either that or a computer can "force" it to regen.
    Aug 2009
    Romania, E.U.
    Trim : Elegance
    Thank you all for answering so fast. Next time I'll make a longer trip I will try the DPF cleanin' and post back here.
