Thread: Belt screech on start up/ switch off (2.2.dti)
    Regular Member Middo's Avatar
    Swindon
    Default Belt screech on start up/ switch off (2.2.dti)
    Is this just a worn belt or is it a knackered tensioner?
    Full Member Big Sig's Avatar
    Probably just the aux belt worn, but it doesn't help to change the tensioner too
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    80% sure you'll need to change the tensioner I bought a belt to do mine but had to change the tensioner as it was solid
    Swindon
    Cheers all, is it an easy job to change the tensioner?
    Regular Member steve's Avatar
    Nov 2007
    Ashington, Northumberland
    Just done mine last night ... took me 1.5 hours. now no squealing although i didnt change the tenioner as it wasn't seised or anything now all seems fine... ... belt cost me £24 inc VAT at main dealers...
    Forfar, Scotland
    Trim : LE/VXR
    Year : 13/07
    Quote Originally Posted by Middo View Post
    Tensioner is held on with 2 torx bolts and is very easy to change although i needed to use a torx spanner on the top bolt as it is tight next to the chassis leg
    Swindon
    Is there a How 2? Its only makes a noise when starting and switching off the engine, so may just do the belt.
    Nov 2007
    Its a simple job.
    1. Jack up car and support
    2. You can remove RH road wheel for access but i didnt
    3. Just above the bottom pulley (biggest one) there is the tensioner
    4. On its backplate is a hex bolt, put a ratchet and socket on there and push anti clockwise. This will release the tension from the belt (but you have to hold it there)
    5. Slip off old belt.
    6. Slowly release tensioner.
    7. Fit new belt and when coming to the last pulley pull back tensioner with ratchet again to allow you to slip belt over the last pulley.
    8. Release tensioner
    All done
    Before you start draw yourself a little diagram of the belt so you know how the new one fits in.
    Also you may want to remove your airbox helps for access from the top.
    HTH Matey
    Swindon
    You Sir are a true gent.
  1. CDTI Aux Belt Chirp - When cold or first start only
    By Leemarksmith in forum Engine & Drivetrain
    Last Post: 16th December 2012, 23:20
  2. Shocks, Belt and Pump to start with.
    By jonnyrasp in forum Vectra C / Signum Car Chat
    Last Post: 27th August 2012, 15:14
  3. 1.9cdti wont start following waterpump/belt fail
    By richsimpson in forum Engine & Drivetrain
    Last Post: 9th March 2011, 19:57
  4. Noisy Aux belt on cold start 2.0T
    By neilbroad in forum Engine & Drivetrain
    Last Post: 27th January 2009, 21:00
  5. misfire and belt noise on start up
    By vectragsi3.2 in forum Engine & Drivetrain
    Last Post: 11th November 2007, 20:57
