Thread: I did the airbox mod...ermmmmm
    Aug 2009
    herts
    Default I did the airbox mod...ermmmmm
    It does idle smoother. No wobble at cold idling in neutral when just turned over and started.
    It pulls smoother through the gears-and less accelerator pedal is needed to move the beast along. The lag feels lessened as the turbo spools up.
    Dare I say it, the first gear hesitation is better, now the EGR is cleaned, Boost Valve cleaned, and now the plastic air box part removed...
    ...So, why is the plastic bit there in the airbox? Everything does has a purpose right? Any long term damage concerns with the plastic part removed permanently? Is is there to keep the frost off the MAF on colder mornings as a shield etc?
    Ta.
    Jun 2009
    Norwich
    make a blanking plate for EGR valve two holes 6.5 mm, sweet! Then have the whole air intake rail off and cleaned!
    Regular Member Simo87's Avatar
    Jan 2008
    Middle Wallop
    Quote Originally Posted by cjamesenorf View Post
    6.5 mm for the plate to be attached or holes in the actual plate? have you done this? any vast improvements??
    cheers simo
    Jun 2009
    Norwich
    6.5 mm for the holes in the plate for bolts just .5 mm over bolt size cant remember now had it done for 3 months? had the engine management light on 3 times for 5 secs or so in the first week no limp mode but fine ever since.
    Jan 2008
    Middle Wallop
    cool thanks for the info, may give that an addition to my to do list.
    cheers simo
  1. Airbox mod.....part deux!!! (rip off of VXR280 airbox mod)
    By paul_sri150 in forum Diesel Engine related
    Last Post: 30th January 2012, 22:50
  2. Airbox Mod!!
    By R-ford_Vec_C in forum Vectra C / Signum Car Chat
    Last Post: 2nd June 2010, 14:15
  3. airbox mod
    By andy_hare in forum Vectra C / Signum Car Chat
    Last Post: 10th January 2010, 14:29
  4. Airbox Mod
    By KSD in forum Vectra C / Signum Car Chat
    Last Post: 16th May 2009, 00:49
  5. Airbox mod(But Why)
    By stanian in forum Petrol Engine related
    Last Post: 7th May 2009, 09:49
