Thread: Servicing
    Sep 2009
    campbeltown argyll
    Default Servicing
    not sure if i have put this in the right section but im gonna do a service on the vectra just wondering what oil,spark plugs you would recomend..
    its a 1.8
    Is it less than 3 years old, if so then to retain the warranty it must be serviced at a VAT registered garage, although it is easier to use a VX garage so that warranty repairs can be processed
    If you are doing it yourself, then we need to know the model year and current mileage
    Sep 2009
    campbeltown argyll
    its a vectra c 2003 1.8sri 85k on the clock
    Assuming 8th service / 80K miles :
    Oil and oil filter
    Air Filter
    Pollen Filter
    Spark plugs ***
    Brake Fluid
    Assuming 4th service / 80K miles :
    Oil and oil filter
    Air Filter
    Pollen Filter
    Spark plugs ***
    Brake Fluid
    You will need to check what MY the car is, as this will determine if the cambelt kit should also be included :
    up to MY 2002 - 4 years / 40K miles - if this is the case then this is the cars second cambelt change, so check the service history
    MY 2003 onwards - 6 years / 60K miles
    *** - From engine number 20CK0551***
    A longer interval is possible with different spark plugs
    Sep 2009
    campbeltown argyll
    may sound dumb but is the pollen filter the one just behind the washer jet on passenger side???
    the previous owner has done cam belt and timing belt!!!
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    Yep thats the one buddy, when you change it check the drain holes next to it as if they block ya can end up with a wet footwell
  1. Servicing
    By mickg in forum Vectra C / Signum Car Chat
    Last Post: 8th August 2012, 19:27
  2. Servicing
    By ADAM123 in forum Engine & Drivetrain
    Last Post: 12th March 2010, 13:45
  3. Servicing
    By Ben999 in forum Vectra C / Signum Car Chat
    Last Post: 25th March 2009, 14:43
  4. servicing
    By stuart bigboy in forum Vectra C / Signum Car Chat
    Last Post: 24th February 2008, 10:23
  5. Servicing.
    By bobby_rstevens in forum Vectra C / Signum Car Chat
    Last Post: 18th January 2008, 12:13
