Results 1 to 10 of 15
Thread: Wheel alignment
    Forum Moderator FIL 4822's Avatar
    On a French Carp lake somewhere x
    6 Post(s)
    Vehicle : Insignia VX-line RED Tourer
    Trim : No, over weight!
    Engine : Flux Core Capacitor
    Year : 1 A.D
    Mileage : Rising
    Default Wheel alignment
    Just had my wheel alignment checked and they said that all 4 wheels were out and has cost me £50 to get it sorted.
    The place i went to use a CORGHI computer wheel alignment machine which they promised me is the best and is what the car manufacturers use when setting up the new cars.
    I've had the car 20 months and never got it checked so thought it was about time it was.
    Below are a couple of pictures of the printout. Can anyone tell me how bad/far out the alignment was as i can't make head nor tail of it as it's just numbers to me.
    Sorry about the quality.
    May 2008
    Derbyshire (south)
    to me the front l/h wheel was toe-ing out, & the r/h was toe-ing in, therfore giving the feel that it was pullin to the left.
    I'm not sure on the rears so i can't help.
    I should imagine it feels different to drive, although i wouldn't say it was excessive??
    6 Post(s)
    Year : 1 A.D
    Mileage : Rising
    It wasn't pulling to either side (or didn't fell like it) but when on a motorway or road where lorry's have caused the road to rut, it was a little un-nerving at times.
    I put this down to having 19's on causing it to tramline.
    Tyneside
    Rear cambers not done very well on the new settings. You'd be wanting them as close to identical as possible.
    Regular Member dv8's Avatar
    Apr 2008
    West Mids
    Vehicle : Veccy C
    Trim : SRI
    Engine : CDTi
    Where abouts did you have it done FIL4822??
    might get mine checked...
    6 Post(s)
    Year : 1 A.D
    Mileage : Rising
    Quote Originally Posted by dv8 View Post
    Addison tyre centre - Princes End , Tipton.
    www.discounttyresuk.co.uk
    Carmarthen
    Vehicle : Insignia
    Trim : Sri
    Engine : 140 Ecoflex S/S
    Quote Originally Posted by mark1319 View Post
    Did they put any weights on the drivers or passenger's seats to simulate "actual" loading conditions and how much fuel was in the tank - 1/2 or more or less?
    If I'm reading the before and afters correctly, those in red are outside of the permitted/recommended parameters.
    Looking at the geometry settings from VX, the rear camber angles have been set for a car with a ride height of between 330 and 334mm when measured from the centre of the rear wheel hub/cap to the top of the arch.
    But yes, camber angles should be as near as damn it identical.
    Regular Member old cruiser's Avatar
    slough
    Left hand was toeing in and right hand toeing out, chances are you probably didn't notice any pulling as such on those initial values, but may have incurred some small amount of tyre wear; at least they got the thrust angle vertually correct, which is effectively the, shall we say imaginary center line through the car of which all alignment is based and rears should be set first and then front from there, what does bother me is the fact they are a supposed alignment specialist and have ignored the fact that the rear LH camber is out of spec' and this is adjustable on the vec C, they should have also weighted the passenger and driver seat with 70kg weights and 1/2 a tank of fuel (this is difficult , but can be compensated for if it's not @ 1/2)
    Cheers Pete
    May 2008
    Derbyshire (south)
    The Lh is reading +.8mm i thought this was toe out, the Rh was -1.5mm so its toe-in?
    Carmarthen
    Vehicle : Insignia
    Trim : Sri
    Quote Originally Posted by old cruiser View Post
    Cheers Pete
    Good job we've got Wheels in Motion on our doorstep.
  1. 4 wheel alignment
    By tangoman in forum Vectra C / Signum Car Chat
    Last Post: 16th April 2012, 21:42
  2. wheel alignment
    By matt2005 in forum Suspension, Wheels & Brakes
    Last Post: 8th March 2012, 12:32
  3. 4 Wheel Alignment
    By Tam80 in forum Suspension, Wheels & Brakes
    Last Post: 29th January 2011, 20:06
  4. 4 wheel alignment
    By dave_taiho in forum Northern Ireland (RO - Vacant)
    Last Post: 9th March 2010, 16:35
  5. Wheel Alignment?
    By parapaul in forum Suspension, Wheels & Brakes
    Last Post: 23rd November 2008, 23:09
