Results 1 to 10 of 27
Thread: airbag ecu
    Nov 2007
    lancashire
    Default airbag ecu
    right had a little bump with my car and cutain and seat airbag deployed, replaced airbags now going to change the ecu. can i just change the airbag ecu with another off a undamaged veccy and tech 2 the car to work properly or am i just clutching at straws here
    WGAF#5
    might want to check the seat belt pretensioners havent fired as well
    Nov 2007
    lancashire
    seatbelts seam ok and i dont think have fired,
    Regular Member steve's Avatar
    Nov 2007
    Ashington, Northumberland
    Could be wrong but arn't the ecu linked to main ecu ... i.e. one will only work with its parent ecu... but then again tech2 could possibly get round that like you say....
    Nov 2007
    lancashire
    Nov 2007
    lancashire
    i have seen airbag kits for sale i.e air bag and ecu and thought are things so simple
    Admin plasma's Avatar
    On the Forum
    185 Post(s)
    Engine : 150
    Mileage : 74000
    theres a couple of options open to you. You can either try to get it reset via tech2, but failing that you can swap it over for an exact copy of what you have already. ie if it has rear seat belt pretensioners then the one you fit must it as well. Only downside is you'll never be able to get into the airbag ECU via programming due to it having a code not for your vehicle and also its locked upon first programming..
    Soo... either try to get it reset via tech2, or fit an exact matching airbag ECU
    Plasma's Tech2 services are now partially open and able to provide services
    Come Join our new forum Insignia Owners.com for all your Insignia chat and needs
    Nov 2007
    lancashire
    Nov 2007
    lancashire
    if i get a exact match will it still need going on tech 2
    Nov 2007
    lancashire
    can the airbag light only be reset using tech 2 or will other machine work as well????
  1. Airbag ECU ...
    Last Post: 25th April 2014, 16:42
  2. AIRBAG light .. is thier a fuse the the Airbag ecu ?
    Last Post: 10th September 2011, 13:21
  3. where is airbag ecu
    By wbm156 in forum Vectra C / Signum Car Chat
    Last Post: 13th March 2011, 20:56
  4. Airbag replacement - NSF (front passenger airbag)
    By Caveman_nige in forum Bodywork & Interior
    Last Post: 19th February 2011, 21:12
  5. airbag
    By samuel hosick in forum Vectra C / Signum Car Chat
    Last Post: 18th April 2010, 20:10
