Thread: Stone chips
    Regular Member KTM Chris's Avatar
    Nov 2007
    North Lincolnshire
    Default Stone chips
    I've noticed a couple of chips/small scratches on the roof of my car that I assume have been caused by either stones or something being put on the roof. I've got some touch up pens, but these little chips are down to the metal and are starting to surface rust. Any tips on how to remove the rust on such a small area? I don't want to damage the surrounding paintwork by using sand paper or wet & dry.
    Regular Member bobby-tupper's Avatar
    LEEDS, W.YORKS
    Vehicle : 07 Estate
    i put a small blob of that rust killer stuff on mine then just touched up over the top of it,that was 6 mths ago and no sign of that nasty rust coming back though the paint.
    Regular Member Pete B's Avatar
    Malvern
    Small areas like that, I've always used a small, sharp screwdriver blade edge/tip to remove the rust from the exposed metal and to smooth the edges of the paint. Wipe clean newly exposed metal with meths, then apply a small touch of rust preventer, wipe away with meths after required time, apply a small amount of primer in 2 applications allowing each application to dry. After the second has dried, then 2 or 3 applications of the colour coat & if applicable, laquer. That's always worked for me.
    May 2006
    scotland
    Quote Originally Posted by Pete B View Post
    Yes, thats what I do. I use a jewellers screwdriver to clean the metal. I also make sure any loose paint is chipped away, using this screwdriver. When painting, ensure you seal round the original paint so water cannot creep in behind it otherwise you can end up with water creeping under the paintwork and rusting under the paint.
  1. Stone chips
    By gaz1965 in forum Vectra C / Signum Car Chat
    Last Post: 13th May 2011, 18:28
  2. Stone chips every where
    By Ginge7289 in forum Detailing and Car Care Discussion
    Last Post: 15th February 2011, 12:28
  3. Stone Chips anyone?
    By Keefyb007 in forum Bodywork & Interior
    Last Post: 8th September 2010, 08:26
  4. stone chips.
    By wiggy in forum Detailing and Car Care Discussion
    Last Post: 25th March 2009, 12:32
  5. Stone Chips !!
    By PIMM in forum Vectra C / Signum Car Chat
    Last Post: 1st May 2008, 22:36
