Thread: Cambelt snapped
    plymouth
    Default Cambelt snapped
    Has anybody with the 120 cdti ever had a cambelt snap? It had on mine and i have just found ou the reason. I was cursing the 100k interval after mine had snapped on 72k but it seems there was a darker reason. The vacuum pump thats attached on the end of the cylinder head was to blame!! The drive between the pump and the camshaft is just a bit of cast metal but it snapped in two pieces and jamed the camshaft!! Obviously the belt wont stop the crankshaft from turning so it snapped, if the garage that i bought it off had stamped my service book properly then i could probably have tried to get cash off vx to help.
    Are you VXR Enough
    13 Post(s)
    Engine : 6.0 V8 Thunder
    oh thats not good bud is there much damage
    Regular Member paul wingnut's Avatar
    durham
    Vehicle : vectra sri 150
    Engine : 1900 cdti 150
    you may get away without any valve damage the valves r sraight up and down try a belt kit and pump and give it a try you might be lucky
    plymouth
    nah it trashed all the valves
    plymouth
    and beacuse the vacuum pump locked the camshaft the pulley was damaged too, it ripped the key right off the pulley
  1. Snapped exhaust manifold/turbo stud snapped in cylinder head!
    By XPCobra in forum Engine & Drivetrain
    Last Post: 7th May 2012, 10:50
  2. Snapped door pin rod!
    By rosssri in forum Vectra C / Signum Car Chat
    Last Post: 8th April 2012, 17:38
  3. cdti 150 cambelt snapped
    By chucky121 in forum Engine & Drivetrain
    Last Post: 29th August 2011, 22:35
  4. Oh no i've snapped it
    By mr.c72 in forum Engine & Drivetrain
    Last Post: 16th June 2010, 18:14
  5. Springs snapped.
    By falco in forum Suspension, Wheels & Brakes
    Last Post: 28th March 2009, 14:18
