Thread: Opel Vectra C 2.2
    Sep 2009
    Istar
    Default Opel Vectra C 2.2
    Hi guys,
    I have got a problem here and it looks so:
    After washing up of car engine it started normally but for next start it didn't come on again. Check lamp is off; it is not possible to connect to ECU
    while other modules have number of faults.
    It seems that there is a big problem with ECU now I wish to buy another second hand ECU+IMMO+KEYS but I need your help with immo can you tell me please where is immo in the Opel Vectra C?
    Dilick
    Regular Member kenp's Avatar
    Kr. Hyllinge, Denmark
    Engine : 2.2 Direct
    let it dry out.. probaly got water in the modules.. maby that will help.
    Sep 2009
    Istar
    Quote Originally Posted by kenp View Post
    thanks boddy,
    but it's already the 3rd day not probably but actually modules got water in
    and now they all are dried out.
    any other suggestions would be very useful
    as for immo isn't that integrated in CIM?
    Engine : 2.2 Direct
    yes the Immo is in the CIM
    Regular Member rushy's Avatar
    Vehicle : SRi
    Engine : Z22SE (2.2 Petrol)
    Mileage : 137000
    Have you checked the plugs on the Engine ECU and ABS plug? The ECU on the 2.2 is bolted to the intake manifold with 2 large plugs attached and the ABS module is up behind the battery.
    Sep 2009
    Istar
    yes sure I have already checked the plug on the ECU and as for ABS plugs not yet does it affect engine start and Check lamp presence?
    I tried to scan it but there is no connection possible with ECU
    while I easily got access to other modules (ABS, IMMO, SDM, IPS and others) they all got number of faults.
    the main problem is that I could not get connected to ECU?
    Vehicle : SRi
    Mileage : 137000
    A wet or dirty ABS plug can cause the same faults as a faulty CIM. Mine wouldn't start, dash lights all over the place........... A good clean and all was well.
  1. Vectra B DTI CDX, but its an OPEL!!!
    By Vaux-Man-G in forum General Motoring Chat
    Last Post: 28th April 2012, 22:42
  2. Opel Vectra C GTS 2.0T
    By Urkraft-2 in forum Introduce yourself.
    Last Post: 27th November 2010, 18:17
  3. More Vectra/Opel from W.A
    By Vectra_C_Chris in forum Quick Photo Album
    Last Post: 11th November 2009, 08:07
  4. New Opel Vectra
    By Cornel in forum Quick Photo Album
    Last Post: 6th September 2008, 11:24
