Results 1 to 10 of 15
Thread: Yellow warning light regarding bulb.
    Regular Member Danialj32's Avatar
    Sep 2009
    Warrington
    Default Yellow warning light regarding bulb.
    Hey, had a bulb go on my vectra C 2002 (52) LS 2.2, I was alerted with the yellow warning light come on in the dashboard, so I bought some H7 xenon bulbs off ebay for about £3, and got the side lights for about £3 aswell. Just fitted them all (was a real pain getting to the drivers side) and turned the lights on, all lights working, but the yellow light still shows up as if to say I still have a bulb out, any reason why this is so? Thanks.
    Danny.
    Regular Member yadziyad's Avatar
    London
    are you sure one of there rears havent gone too
    Full Member Big Sig's Avatar
    Did you make sure the connections were clean?
    Sep 2009
    Warrington
    Yeah, all bulbs was connected properly, and put back as i removed them :\
    Rear lights are both working fine, very strange. =\
    west yorkshire
    my display tells me which bulb is out
    Sep 2009
    Warrington
    I don't have the trip computer, just a little warning light comes up, in yellow, with a bulb shape, an exclamation mark in the middle and 3 lines diagonally, and horizontally behind the bulb, i'm just assuming this is saying there's a problem with the lights.
    Regular Member benny's Avatar
    Feb 2006
    dudley
    i would bet both your top rear bulbs have blown .....
    It's case of working your way around the bulbs and seeing which has failed
    Usually it is the rear cluster which gives a false positive, the brake lights are sensitive as they are dual-load, as a result you turn on all your lights and indicators, walk round the car and find none have failed
    You should find one of the brake light bulbs has a slightly burnt look to it
    I then swap these on both sides for the tail lamp
    The tail lamp then goes a few weeks later and it gets replaced
    Sep 2009
    Warrington
    From what I can see, both rear lights are working, will have to check brake lights later, when I have company
    It's quite sunny atm, so I could be wrong about the lights, will check later on when the darkness falls.
    Quote Originally Posted by Danialj32 View Post
    I drive to my local petrol station and reverse up to the glass at the car wash, which pretty much acts as a mirror
    I then check the rear tail lights, brake lights, rear fog, and reverse lights
    It is easier during the hours of darkness, but I've done it during daylight without any problem, although the glass in the car wash is new and clean!
  1. bulb warning light
    By woodze in forum Electrical & ICE (including SatNav)
    Last Post: 13th May 2012, 12:23
  2. Orange/Yellow Oil Warning Light
    By countduckula55 in forum Vectra C / Signum Troubleshooting
    Last Post: 10th July 2011, 17:44
  3. Bulb warning light
    By deanos in forum Vectra C / Signum Car Chat
    Last Post: 13th December 2010, 00:13
  4. Bulb Warning Light
    By Exclusive BV in forum Vectra C / Signum Car Chat
    Last Post: 9th July 2010, 16:10
  5. Bulb warning light
    By mike12 in forum Vectra C / Signum Car Chat
    Last Post: 23rd January 2009, 22:23
vauxhall vectra bulb warning light reset
https:www.vectra-c.comforumshowthread.php91726-Yellow-warning-light-regarding-bulb
vauxhall vectra warning light bulb
vectra c bulb warning light
vectra light bulb warning light
light bulb with exclamation mark vectra
vauxhall vectra warning lights bulb exclamation mark
light bulb warning light on vectra
yellow light on vauxhall vectra 2006
vectra c bulb with exclamationVectra c bulb warningvwctra warning sign yellow bulb hughvectra bulb yellow warning lightvauxhall bulb replacement yellowvectra c showing yellow bulb icon2002 Holden Vectra Light bulb warningyellow light on vauxhall vectraVauxhall vectra c orange light bulb on dashopel vectra light bulb signvetra reset replace bulb lightlightbulb sign on vectra dashboardreversing light icon vauxhall vectra vauxhall vectra 2.2 light bulb warning lightsvectra 2006 warning lights
