Results 1 to 10 of 15
Thread: Went for a long trip, but lost all power!
    Default Went for a long trip, but lost all power!
    I left on Friday morning for a long trip
    Glasgow - East Midlands - South Wales - Birmingham - Glasgow
    Roughly 1000 miles on 100 litres
    There was no hurry so the cruise control was set at normal Motorway speed
    I don't normally use cruise control
    I didn't notice any issues all the way from Glasgow to Charnock Richard Services, including refuelling at Carlisle
    Traffic Master and the gantry warnings signs advised of heavy delays after the Thelwall Viaduct, so I took a diversionary route on some B roads for about 20 miles
    However on rejoining the Motorway I noticed there was a distinct lack of power
    I then found the revs would not go above 3000rpm
    Through Derby there some roundabouts and standing traffic, and the symptoms were very clear and obvious
    I was able to accelerate up to 2500rpm, it then felt like the brakes were being applied, there was then more acceleration up to 3000rpm, and then shuddering
    I then phoned my local VX dealership, for advice as the EML light was not on, and advised them the car would need booking in on Monday for inspection
    This went on, but did not get worse as the miles clocked up
    However, it was annoying on my return journey as I was unable to use cruise control in order to keep the car under control
    It was really noticeable there was a distinct lack of power uphill (even a very slight hill), and up Shap and Beattock I ended up being overtaken by lorries, but downhill there was no problem (so much so the revs would easily pass 3000rpm)
    The engine sounds and revs fine on idle
    The turbo sounds to be operating correctly, although it does spin up and then go quiet, but it has to do it a lot!
    However under load there is no power with limited revs at 2500 to 3000rpm
    The EMS light is not showing at any stage
    Equally, the self-diagnostic test returns no faults found
    My first thoughts are the EGR valve has stuck open, due to the long spell on cruise control at low revs, which is something the car doesn't normally do
    Regular Member m3ath3ad's Avatar
    Aug 2007
    Minehead
    i went from blackpool to taunton on the motorway with cruise on set to 80 and had no probs, got to the round about and put me foot down to clear the pipes seems to be all fine
    It's impossible to put the "foot down"
    The 0-60 mph time must be about 30 seconds
    Although the first 30mph are as normal!
    The 30-50 mph would have to be measured in miles not seconds
    Anyone got any idea what is wrong then?
    May 2007
    southend on sea
    i'd take the egr valve off and have a look at it, very good how to on here.
    Quote Originally Posted by drewdrewuk View Post
    Yes, had a look earlier, but doesn't cover the Y30DT engine
    The car is under warranty, so let's see if that is their diagnosis...
    As above, I normally only use the Cruise Control for short periods, and I suspect having used it for much longer than normal the butterfly valves have ceased
    Typical dealership though, unlilkely to remove and clean, replace with new only
    Equally, I believe there is a waiting time of at least three weeks on EGR valves on this engine
    However, if the VX dealership confirm it is the EGR valve, then I may search for another VX dealership with a SAAB branch (as Arnold Clark don't have any SAAB dealerships)
    Ian Grieve in Stirling have both
    Regular Member Celes's Avatar
    Slovenia, Koper
    Vehicle : Opel Signum
    Trim : Sport
    Engine : 3.0 CDTI
    Year : 12/03
    I say it is unlikey to be the EGR mate. That would show a code.
    Check for split hoses. Sounds remarkably like what happend when I forgot to tighten the clip holding the pipe going into the manifold.
    VIP-Member brifen's Avatar
    Fareham
    Vehicle : Vauxhall Signum 2.0 DTI (Irmscher)
    Trim : Elegance
    Engine : 2.0 DTI 100 bhp
    It actually sounds like a bust boost hose or a simple vacuum pipe to me? I know you would normally get the full EML and limp mode and error codes stored but you may just be getting enough of a reading to keep the light off?
    Interesting to find out the cause though.
    Bri.
    Today!! The new tomorrow, live the NOW!!
    EVERYWHERE
    I'd go with a leak in the intercooler system too.The hose coming off the turbo was very loose on mine a while back!
    The car was with the dealership this morning
    Phoned me at 16:00 to advise they had performed a TEC2 and it had returned codes for faulty injectors
    I queried that as neither had the engine gone into safe mode nor the engine management light had not come on
    They advised that in some cases only the fault code is stored, if deemed less serious (but I've never heard of that before!)
    The dealership had (allegedly) removed the faults code, performed a road test and confirmed the car was driving better
    However, I found no difference
    Waiting for a phone call for parts to arrive, then I will report back on what is actually wrong, whether it is a specific injector, or the injector rail
  1. Lost power from 12v sockets..
    By Steven in forum Electrical & ICE (including SatNav)
    Last Post: 21st December 2012, 00:06
  2. faults or service req/long trip
    By madman in forum Vectra C / Signum Car Chat
    Last Post: 28th October 2010, 05:25
  3. Just lost all power at 3000 rpm on 3.0 V6 CDTi
    By neverton in forum Engine & Drivetrain
    Last Post: 24th May 2010, 12:27
  4. I've lost power some where!
    By John LE in forum Diesel Engine related
    Last Post: 29th March 2010, 11:10
  5. help required(lost power)
    By bbb69 in forum Vectra C / Signum Car Chat
    Last Post: 8th February 2010, 19:00
