Thread: poor handling vec c
    Sep 2009
    Default poor handling vec c
    hi peeps
    Im in need for some. I bought my 1st vec c 2 days ago.
    But the handling is realy poor. Doing 20-30mph over a pot hole and u can feel the rear end slip to the driver side. You normaly tend to feel this when u have bold tyres.
    Ive had a look at it myslf and took it to the garage today.
    Evrything seems fine.
    Tyres are good.
    Suspension is good, no leaks or broken springs.
    Any1 any idea what it could be?
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    99.9% sure its rear upper suspension arms. Very common vec problem. With the car sitting on the ground, pull on the top of the rear wheel and you should feel a clunk if one or both have gone, Hope that helps
    Sep 2009
    the car does seem to dip more on the passenger side rear. When going over humps. Could that be due to the uppar arm being warn aswel ?
    Forfar, Scotland
    Trim : LE/VXR
    Year : 13/07
    That could be a knackered shock absorber, another common problem lol
    Apr 2008
    Limerick
    As John Robertson says it probably the rear upp suspension arms, not hard to check for and not that hard to replace, there are 'how tos' in this forum. When they are gone it makes the car feel like its been steered from the rear!
  1. Poor handling in wet?
    By thespirit3 in forum Vectra C / Signum Car Chat
    Last Post: 15th July 2009, 13:14
  2. New tryres - Poor handling
    By jamesr in forum Handling & Braking
    Last Post: 31st August 2008, 20:45
  3. Vectra poor handling
    By Duncan in forum Suspension, Wheels & Brakes
    Last Post: 5th July 2008, 19:13
  4. Poor handling
    By Gaz the Cab in forum Suspension, Wheels & Brakes
    Last Post: 22nd February 2008, 00:07
  5. Poor handling
    By Gaz the Cab in forum Handling & Braking
    Last Post: 9th February 2008, 11:29
