Thread: blower speed
    Sep 2009
    north lanarkshire
    Default blower speed
    hi guys .
    just got 1.8i ls 04 vectra got some faults
    1.blower motor only works on no.4 speed 1.2,3. nothing.
    when i start car up im getting a clicking sort of sound from behind the blower controls.
    2.air con button nothing when switched on but revs go up a bit.
    3 passenger window switch goes up but not down.
    are these simple faults to fix.
    Regular Member paul wingnut's Avatar
    durham
    Vehicle : vectra sri 150
    Engine : 1900 cdti 150
    the heater wont be working by the resistor giving up check near pollen filter for bulk head drain blocked water then goes into heater motor taking out resistor behind glovebox could also have a faulty switch does it work ok from driver side?
    Sep 2009
    north lanarkshire
    hi bud.
    yes it works ok on drivers side.thanks
    durham
    more than likely faulty switch ...
    Sep 2009
    north lanarkshire
    thanks again.i will change it over.
    with the resistor giving up is this whats making clicking sound behind the glove box every time i turn on ignition?.
    thanks again
    durham
    yes there's a relay which controls fan on left side of glovebox. i had same trouble with mine fitted a new resistor worked ok for a while but went off again water had got into motor taking its toll had to have a new motor new motor has 2 drain holes in bottom to drain any moisture that collects but it worked ok on no4 speed make sure you check under flap where pollen filter is thats what starts all the problems its a black rubber boot thing ....motor isn't cheap 140 quid from dealer plus vat resistor about 25quid good luck m8..
    Sep 2009
    north lanarkshire
    cheers bud.
  1. blower speed 4 not working. 1,2,3 OK
    By sunbeam in forum Electrical & ICE (including SatNav)
    Last Post: 4th March 2013, 15:55
  2. Signum Blower/Fan Only Works on Speed 4
    By Gayno in forum Electrical & ICE (including SatNav)
    Last Post: 15th April 2012, 13:31
  3. heater blower only works on 4 speed
    By hippo in forum Heating, Ventilation & Air Conditioning (HVAC)
    Last Post: 9th February 2010, 14:38
  4. Wierd prob with fan blower speed control
    By Nosher in forum Vectra C / Signum Troubleshooting
    Last Post: 3rd May 2009, 11:10
vectra c blower not working on 1.2.3 but 4 works
