Results 1 to 10 of 13
Thread: DTUK Green Issue
    May 2008
    south east
    Default DTUK Green Issue
    I am having a problem with a Green DTUK unit that i purchased from Fleebay and my Vectra SRI 150 cdti Estate (2005)
    when the unit is connected the car starts and drives fine from cold but after say a 30 mile drive when I try to restart the car it refuses(just turns over not even trying to start) but once I remove the unit the car starts first turn just like normal?
    the unit is set to approx 12.30 tried it at 12 but got elm light and limp home mode although no smoke (it never smokes no matter how hard you push it?)
    Any body got any ideas
    Regular Member axelf's Avatar
    chester le street
    Hello m8.... give andrew a ring from DTUK (it his company and he is helpfull 08448 845 007 07977 466 007 i got an eco 3 and it goin fine....hope this helps you...
    lanark
    5 Post(s)
    Vehicle : Insignia Elite Nav
    Year : 2012
    Mileage : 9k
    can't think what that could be i was going to say maybe you had it connected the wrong way round which is quite easy to do but that should have brought up a warning straight away even though it would have still driven
    May 2008
    south east
    Cheers Guys
    I thought i had checked and double checked the connections but i will try that again in the morning.
    when it arrived the unit was set at 11:30 and the car went like stink but it cut out and died whilst crawling in trafic
    When it restarted all was fine again for an hour until in trafic again the elm light popped up and it went into limp mode so i diconnected it and turned it up/dowd to 12:30 and headed home to reset the light.
    This morning all was well and i could feel the power in 5th gear and enjoyed driving though the country lanes, it was nice not to have to keep dropping into 4th at every hill.
    But it just wouldnt start again after we parked upfor half an hour
    EVERYWHERE
    It could be a faulty box.The car not starting again could be that the signal from the pressure sensor isn't reaching the ECU and so you will have zero fuel pressure when it comes to start the car.It could be that the box is getting too hot or the connections aren't too good.
    May 2008
    south east
    thanks Dd
    i was sort of thinking the same thing but not actually sure what would happen if there was no signal.
    does any one know what the signal should be so that i can test it?
    EVERYWHERE
    Quote Originally Posted by vex View Post
    Normally the voltage in the signal wire should range between 0 and 5 volts (possibly more than 5 with the tuning box fitted).I have no idea which one is the signal wire on your box.
    May 2008
    south east
    Default update
    Hi People
    sorry for the long time between posts but have been away working any way just been out in the car and again it died whilst gently pulling away from a roundabout.
    any way the car restarted and went into limp home mode which gave me a chance to look for fault codes.
    P0002 - Fuel Metering Solenoid Valve Circuit Range/Performance
    (5B) - Not present
    P0090 - Rail Pressure Control Solenoid Valve Circuit Range/Performance (Positive Deviation)
    (0A) - Not present
    is this typical af over adjustment? its just that i get no smoke but then the car does hjave a DPF?
    Regular Member MattW's Avatar
    Sheffield
    Sounds like a dodgy box to be honest. Buy direct from DTUK, and you get a 3 year warrenty on the box itself.
    EVERYWHERE
    I wouldn't have a 'box' on a DPF fitted car-full stop.All that's happening is that all the soot particles are being held by the DPF until it's time to 'regenerate'.In the meantime your DPF is getting stuffed up with soot that it would not normally expect to deal with.
    I'm not sure how it's at all possible that something that is going to produce more smoke particles is not going to do the DPF serious damage over a period of time.
  1. dtuk green or red box ????
    By paulf in forum Diesel Engine related
    Last Post: 23rd August 2012, 08:59
  2. Whats the difference between dtuk green and dtuk red?????
    By srinav in forum Vectra C / Signum Car Chat
    Last Post: 30th August 2011, 10:04
  3. DTUK Green Box
    By bruceybonus in forum Parts for sale
    Last Post: 25th May 2009, 17:14
  4. DTUK Green Box
    By andy13 in forum Parts for sale
    Last Post: 10th January 2009, 13:17
  5. DTUK Green Box
    By Gaz the Cab in forum Parts for sale
    Last Post: 6th October 2008, 14:24
dtuk unit and p0002
