Thread: locking the engine for cambelt change 1.9cdti 150
    Apr 2008
    Kidderminster
    Default locking the engine for cambelt change 1.9cdti 150
    Chaps,
    I am following the how to for the cambelt change on a cdti150, and am trying to remove the crank fanbelt pully. I have tried having the car in gear with foot on brake but there is still too much give in the engine to crack the pully bolt.
    Is there any other way of locking the engine to remove this bolt?
    Regular Member benny's Avatar
    Feb 2006
    dudley
    ???????????? why are you undoing the crank pulley bolt ?????????????????????????????
    note you dont have to undo it to do a cam belt and it is left hand thread !!!!!
    Apr 2008
    Kidderminster
    I have removed the 4 bolts on the crank fan belt pully but i thought i also needed to undo the 19mm centre bolt to release it. Should it come off with just the 4 small bolts removed and if so what sort of persuasion should I use?
    Feb 2006
    dudley
    if you remove the four ribes that hold the bottom pulley on it will come of you may need to show it who is boss ....try prying it gentley ....
  1. Replies: 25
    Last Post: 15th July 2012, 08:05
  2. 1.9cdti Cambelt Change - 'Top Dead Centre' Question...
    By snapsnap in forum Vectra C / Signum Car Chat
    Last Post: 22nd May 2012, 16:37
  3. Cambelt Change On 2004 Vectra 1.9cdti Sri 150
    By PAULMAC77 in forum Vectra C / Signum Car Chat
    Last Post: 25th June 2008, 11:24
  4. Cambelt on 1.9cdti 16v
    By big nath in forum Engine & Drivetrain
    Last Post: 23rd June 2008, 19:55
