Thread: Damned electrical boot release
    Oct 2007
    Gloucester
    Default Damned electrical boot release
    The electric motor for my boot release has been temperamental recently, which I thought was possibly an electrical gremlin. Alas, it's not playing ball at all today which isn't ideal.
    Has anyone else had this problem on their Vectra hatchback? If so, what's the easiest way to solve the problem?
    Regular Member yadziyad's Avatar
    London
    if you use the key in the lock on the tailgate you can open it like that
    Regular Member purple170503's Avatar
    kent
    I've had similar problems which I am tackiling Vx about as apparently it has never happened before, I would put my thread on here but not sure how to, glad Im not the only one though! Just as a guess its about £250 to get gone by Vax if its the locking mechamism itself
    Oct 2007
    Gloucester
    I wonder if it's got something to do with using the pressure washer. I've never deliberately sprayed water into the lock, but there's no sign of any action from the boot release mechanism.
    Has anyone had to replace their boot release mechanism? If so, how expensive?
    West London
    i had to have the boot lock motor replace, but it was under warranty so i dont know how much, however, it was only changed in november last year (it jammed up, so wouldnt lock shut) and my model has no key to do it manually. Occasionally now ill press the button and it will "wherrrr" and not open, have to push the boot down then press the button.
    May 2007
    West Yorkshire
    I had a similar issue on my facelift estate, a strip down and clean of the switch cured it.
    Oct 2007
    Gloucester
    Quote Originally Posted by sshooie View Post
    If I had the tools and any technical awareness I'd have a go. Alas, I have neither.
    My motor did have a period when it would whirr and eventually open, but this time, it seems to have stopped altogether.
    Might it be worth taking it in to an independent and get them to have a look instead of being rogered by Vxl?
  1. Remote Boot Release??
    By andythilo in forum Insignia Chat (READ ONLY)
    Last Post: 31st January 2011, 13:46
  2. Signum boot release
    By dave_3 in forum Electrical & ICE (including SatNav)
    Last Post: 16th January 2011, 13:33
  3. Remote boot release
    By RN37 VXL in forum Bodywork & Interior
    Last Post: 17th October 2009, 17:34
  4. Boot Release
    By DaveD in forum Styling
    Last Post: 14th August 2009, 10:18
  5. Boot Release
    By Drew in forum Vectra C / Signum Car Chat
    Last Post: 8th February 2009, 22:34
vectra c boot release not working site:www.vectra-c.com
