Thread: vectra c special bolt on caliper
    uk
    Default vectra c special bolt on caliper
    hello guys
    just popped into as if anyone knows the type of tool i'd be looking for to unbolt the caliper to swing it back to replace the front pads
    i had some free time today and decided to change the pads and discs, got all changed ,got the wheels off and then i was scuppered i had to call it a day due to not having the tool to loosen the caliper bolts
    if anyone could tell me what type of bolt it is and size
    many thanks guys
    Gary
    Admin plasma's Avatar
    On the Forum
    219 Post(s)
    Engine : 150
    Mileage : 74000
    think its a 7 or 8mm allen key?
    Plasma's Tech2 services are now partially open and able to provide services
    Come Join our new forum Insignia Owners.com for all your Insignia chat and needs
    uk
    looked like some sort of star shaped fitting
    then again i was on the beers last night LoL
    On the Forum
    219 Post(s)
    Engine : 150
    Mileage : 74000
    you was probably seeing the carrier fixing which are e18 or e20 torx bolts
    the allen key bolts are probably hidden by 2 plastic caps coming out from what looks like a plastic tube end
    Regular Member hagga's Avatar
    kingswinford
    7mm allen key under plastic caps
    uk
    cheers guys ,gave it an oil and filter change too,get the wheels back off tomorrow and have another look
    many thanks
    G
    Regular Member Readster's Avatar
    Plymouth
    Machine Mart sell the eTorx sockets you need.
    If you remove the calliper carrier brackets.
    They will be tight...
    So a long breaker bar is a good idea and and a torque wrench too.
    There are some earlier threads and how too's about the trials and tribulations of Vec pad & disc changes that may help you matey
    Regular Member MrLOL's Avatar
    Wakefield, West Yorks
    Heres the back of the caliper
    With the caps removed
    And with the 7mm allen key in
    thats the 2 bolts you need to undo. The torx bolts are for the carrier. You wont need to remove these unless you need to change the discs.
  1. Special Edition 888 Vectra
    By Big-Pete in forum Vectra C / Signum Car Chat
    Last Post: 6th October 2015, 22:43
  2. Vectra SRI V6 Special
    By winty234 in forum Vectra C / Signum Car Chat
    Last Post: 27th July 2010, 11:47
  3. 349BHP Vectra C GSI ---- Very Special Edition
    By n_hudson in forum Vectra C / Signum Car Chat
    Last Post: 8th June 2010, 16:59
  4. Replies: 14
    Last Post: 27th March 2006, 11:51
vectra caliper bolts
