Thread: Air Con hose fracture?
    Regular Member Silentknight's Avatar
    Swindon
    Default Air Con hose fracture?
    I have just asked a local independent garage (who are doing my service for £115.00) for a re-gas quote. They said £49.95.
    They checked it and told me they found a small fracture in one of the pipes and the new pipe would be £49.95 plus labour.
    Total quote £169.99 including labour to fix pipe, re-gas and pressure check.
    Does anyone have a clue how I can check the pipe, is it easy to get to, and does this price sound about right?
    WGAF#5
    when you pick it up ask them to show you the location - then go to a smaller garage and show them - and get the work done for a fraction of the cost
    Swindon
    That was a smaller garage, unfortunately!! Do think it should be cheaper then?
    WGAF#5
    evacuate the ac - remove a ac pipe and refit dependant on the location of the pipe i would summise .60 of an hour (remember techicians deal in 100's for an hour so 36 minutes to replace a pipe then regas
    so based on pipe £49.95
    regas based on £49.95
    leaves you with 70.09 for 36 minutes work !! main dealers are only around £70 plus vat an hour even if you based the work on an hour including regas as they can start a machine set it and walk away till its finished that would be an hourly rate of £120.04
    Swindon
    When you put it like that! Thieving gits......
    WGAF#5
    of course it may take them longer but ask them what the rts is on the repair ?
    (repair time schedule) then work it out for youself
  1. Boost hose
    By woody in shetland in forum Vectra C / Signum Car Chat
    Last Post: 9th December 2012, 09:58
  2. What hose is this??
    By glasgowdarren in forum Vectra C / Signum Car Chat
    Last Post: 3rd August 2012, 22:04
  3. Name that hose?
    By garetmcc79 in forum Vectra C / Signum Troubleshooting
    Last Post: 16th May 2012, 17:09
  4. airbox hose
    By 19CDTi in forum Vectra C / Signum Car Chat
    Last Post: 8th January 2010, 23:56
  5. vac hose on 3.2
    By hagga in forum Engine & Drivetrain
    Last Post: 3rd July 2007, 16:48
