Thread: Wheel bearings - again
    Apr 2006
    Southampton
    Default Wheel bearings - again
    OK. Ive got wheel bearing whine which I thought was coming from the nearside rear but couldn't be sure it wasn't from the front as the noise appeard to move if you know what I mean. Jacked it up, checked the rear and sure enough lots of play. Duely replaced.
    Still got noise. Other rear is fine - or should I say it has no play. When I check the fronts there is play through the wheels on both sides but only in the horizontal plane ( 9 - 3). Recently Ive had to replace warped discs (nearside) and the offside tyre has started to go off on the inside edge.
    Cars done about 60k. Thoughts?
    Nicking Ya Dinner.
    Tis all those traffic lights and road humps Mr King installed in the city thats caused it
    Apr 2006
    Southampton
    You ain't kidding.
    Nicking Ya Dinner.
    Thats what happens when you let an eccentric cyclist be chief road planner, what a joke, next thing will be Commandos in the creche looking after babies, talk about the worst cobi, how can a cyclist do that job?
    Apr 2006
    Southampton
    Who is it then?
    Nicking Ya Dinner.
    Peter King, he was chief engineer for roads about 6 yrs ago, he's left his legacy all over Southampton.
    Apr 2006
    Southampton
    No relation as far as I'm aware. The speed humps are bad enough but the ammount of
    lights drive me insane.
    Nicking Ya Dinner.
    LOL, I should hope not either, he lives on the IOW, rides a bike that you lay horizontal on, I'll leave it to your own imagination.
    Apr 2006
    Southampton
    It's not you is it?
    South East
    Kinger, play on the front horizontally can be movement in steering which can be expected as you are effectively trying to turn the other wheel which is on the ground, try it again with someone checking the steering wheel I bet it moves a tad. You wear on the tyre can be lots of thing esp. the inside edge.
    Bushes also can give the play making you think that a bearing is out. I get what can be described as bearing noise from the rear, this was apparent on my veccy B and in both cases it is the tyres. Change is road surfaces will demonstrate this.
    Hope this helps
  1. Wheel Bearings?
    By PedroMV6 in forum Vectra C / Signum Car Chat
    Last Post: 13th February 2011, 16:56
  2. wheel bearings ????
    By MID LIFE CRISIS in forum Vectra C / Signum Car Chat
    Last Post: 1st February 2010, 20:52
  3. Wheel Bearings
    By Hendry in forum Vectra C / Signum Car Chat
    Last Post: 18th August 2009, 13:52
  4. Wheel bearings
    By Days of thunder in forum Suspension, Wheels & Brakes
    Last Post: 23rd May 2008, 08:26
  5. Wheel bearings
    By Padster72 in forum Suspension, Wheels & Brakes
    Last Post: 8th April 2008, 10:08
