Page 1 of 4 123 ... LastLast
Results 1 to 10 of 34
Thread: clutch problem please help
    Regular Member v33tra's Avatar
    ayrshire,scotland
    Default clutch problem please help
    ok one of my vectra c`s is driving me up the blooming wall ( well it would if i could get it to drive any great distance reliably )
    ok the car details
    2004 vectra 2.0 dti ( y20dth )
    the problem
    dual mass flywheel was rattling and the clutch started to slip
    work carried out so far
    dual mass flywheel replaced
    clutch replaced
    clutch cover replaced
    concentric slave cylinder replaced
    all flywheel bolts replaced
    clutch cover bolts replaced
    gearbox oil replaced
    all the above brand new parts
    car put back together clutch system bled and car road tested
    NOW A NEW FAULT ARISES
    this is what i need help / advice with
    the clutch is bled up peddle feels great biting point good until you road test it a couple of miles then clutch peddle starts to fade away until biting point is on floor and little or no resistence to peddle gear changes become difficult
    bled system again same scenario occurs within 2 miles,this system has now been bleed manually and with a pressurised bleed machine over 20 times still same fault occurs
    so today a brand new clutch master cylinder is fitted and clutch spring modification carried out i.e the one that fixes cruise control
    bled system up road test same fault occurs again,5 more times i`ve bled the system up clutch peddle continues to fail on road test
    no fluid loss on any of these road tests is apparant and reservoir level remains same and the peddle gets better by pumping it several times but fades away again when driving
    this is deffo an air in system fault but i can`t source the cause or cure it however it may be a faulty new slave cylinder but how can i prove that without having to remove the gearbox again
    any advice really gratefully recieved if anyone has encountered similar vectra clutch bleeding issues
    my next course of action in the meantime is to replace the hydraulic flexi pipe that feeds the slave cylinder but that wont arrive until saturday
    thankyou in advance if you reply with advice
    Jul 2009
    barnsley,yorkshire,GB
    Engine : 20 Dti
    vx have come up with a revised bleeding proceedure it's worth a try.
    fit a rubber tube to ventilator valve,put open end into a clean container with enough brake fluid to cover tube end,press cluth pedal to floor and hold there,open valve untill fluid runs out without air bubbles (you will need someone in car to hold down pedal)close valve,then pull pedal back to stop but not too quickly,wait 5 seconds,repeat this 4 times tighten valve (not too tight 5 Nm)don't forget to keep resorvoir full all the time.top up fluid and test drive vehicle.
    it's a bit of a fiddle but worth a try bud,
    air get's traped in system because of vx's poor design (surprise surprise)
    Regular Member benny's Avatar
    Feb 2006
    dudley
    could be two things .....is the clutch drive plate in the correct way round ? ...... if it is in the correct way i would go for the clutch master cylinder the seal could be week / letteing in air .....
    ayrshire,scotland
    Quote Originally Posted by jonnybravo View Post
    already tried that method but still the pedal fails
    thankyou for taking the time to advise of it though any help gratefully recieved
    ayrshire,scotland
    Quote Originally Posted by benny View Post
    master cylinder was replaced with a new one today and fault still there
    99% sure clutch plate is in correct way although 1% of doubt the more i think about it
    why would that cause this fault if you can explain in detail as we can bleed up a great feeling pedal and good biting point it just fades away to a crap one after a few miles but bleeds back up easily again
    also pumping pedal a few times when driving improves the biting point and pedal feel but it fades away again with use until you pump it again
    thankyou for replying and welcome any more thoughts
    Jul 2009
    Engine : 20 Dti
    if it pumps up as you say then you lose pedal it has to be master or slave cylinder,the fluid is by passing the seal and pumping up re prime's the cylinder.that's assuming you arn't losing any fluid externally
    Feb 2006
    dudley
    are the seals on the pipes that go into the box and come from the master cylinder all ok one hasnt peeled over or has a nick in it ..?
    Jul 2009
    lanark
    pretty sure you have a faulty hydraulic valve.
    on your actuator pipe, follow it back to the master cylinder, there is a round valve, almost the size of 2 jammy dodgers stuck together on the pipe, these cause symptoms like this, they draw air through the seal and therefor spongey clutch.
    the valve is black or silver depending on model.
    ayrshire,scotland
    Quote Originally Posted by vxr-jim View Post
    this is ordered VOR today but won`t arrive until tuesday worth a try as it`s the last external part also comes with the metal pipe if that fails to cure the fault it`s gearbox back out
    ayrshire,scotland
    as far as i can tell mate by tuesday every external part will have been changed and the only things after that left will be the bleed nipple housing the metal pipe in the gearbox and the new slave cylinder itself but these 3 parts require gearbox removal to check again that they are ok
  1. Clutch problem
    By shayom in forum Engine & Drivetrain
    Last Post: 10th May 2012, 23:34
  2. Clutch problem!
    By kel123 in forum Engine & Drivetrain
    Last Post: 5th October 2011, 16:07
  3. Clutch Problem
    By ickleric in forum Engine & Drivetrain
    Last Post: 31st January 2011, 19:19
  4. clutch problem?
    By darko2301 in forum Engine & Drivetrain
    Last Post: 10th April 2009, 21:33
  5. Clutch Problem
    By Aimee in forum Engine & Drivetrain
    Last Post: 30th August 2006, 23:31
vectra c clutch wont bleed
vectra c clutch drive plate bolts
