Thread: Brakelights
    Regular Member VECTRA HEAD's Avatar
    Derry
    Default Brakelights
    I need some help guys if possible,i got home from work today to be greeted by my wife explaining to me that the brakelights on my veccy are staying on and they wont go off.Has anyone got any ideas what the problem might be,I have removed the fuse in the mean time.I also should mention that i replaced my 3rd brakelight about 5 weeks ago but i have had no problems since i fitted it.
    nottingham
    Look down by the brake pedal and there should be a push switch and it should be adjustable so adjust it and test each time you adjust it half a turn at a time. hope this helps.
    Derry
    is it up behind the pedal m8?
    Full Member Robsey's Avatar
    North East Cheshire
    23 Post(s)
    Trim : Energy
    Mileage : 131,000
    I have seen it written, that if no matter what you try regarding the brake lights / pedal switch etc...if you still can't get the brake lights to go out, then this is said to be a tell tale that the "main" ecu has a fault on it.
    What they mean by main I don't know as there are well over a dozen used in the Vectra C.
    Stealer visit will be needed unless you have a friend with Tech 2 equipment.
    Derry
    Well heres one guys,i removed the no.6 fuse (as it says on the manual that this controls the brakelights)and the lights went out,however when driving the car last night i noticed that the brake lights were working as normal!!Any ideas on what is going on with mycar?
    Regular Member Dippy-Vx-line Red's Avatar
    Earlston (Scottish Borders)
    Hi..my brother-in-law was having probs with his lights and he couldn`t fatham waht was going on...Then someone told him to take out the hazard warning switch and hey presto lights all working again..Worth a try!!.Couldn`t beleive that a faulty switch could do this to the lights..
    nottingham
    yes the switch is normally behind the pedal at the top. ive sorted a few of my friends cars like this but i will check my vectra tomorrow and post wot i find.
    Derry
    Daz did you replace or adjust the switch on your mates cars?
    nottingham
    i adjusted it as it was held by 2 nuts so undoing one whilst tightening the other and then checking to see if the lights went on and off although these were citroens not vauxhalls but i would have thought they would be a similar idea.
