Results 1 to 3 of 3
Thread: Heater blower stopped working
    Sep 2009
    lincoln
    Default Heater blower stopped working
    Hi
    my heater blower has stopped working. Iv checked the fuses and they seem fine. When i turn the blower dial 1 through 4 nothing happens but when i push the clear windowscreen button its starts to blow air onto the window. Is it the same blower for the cockpit vents as the one that blows onto the window? If so then i can rule out the blower itself. Any other ideas? Maybe its the toble switch itself. is the any quick fault diagnosis i can do to find out what the problem is??
    Thanks so much, and feedback will be greatly appreciated
    Alan.
    Jul 2009
    Walsall
    Quote Originally Posted by owb82 View Post
    Hi
    Alan.
    what make/ model have you got?
    ive got the same problem with my 53plate signum - if you trawl the forums here there are a few examples of the same problem - think its an inherent fault with the design of the heating system that means the rheostat fails when water gets into it via the pollen filter?
    New Member dalelad's Avatar
    Sep 2009
    Lancs
    I've got a similar problem with my 53 Signum. Washed it on Tuesday and the heater made a noise like a constipated frog then stopped working even though the settings changed when I moved the dials. I've left it for a couple of days while I got my sister's Audi remapped.
    Went back to pick the car up tonight and the heater's running before I even get into the sodding car! Now I can't stop it! It's in for MOT tomorrow, so I've taken the fuse out. God knows what's going to happen when I put the fuse back in - maybe it'll change into a Saab? I'll keep you posted.....
  1. Heater Blower Motor suddenly stopped
    By Snizzers in forum Electrical & ICE (including SatNav)
    Last Post: 15th December 2012, 22:58
  2. Heater stopped working on my Vecra 52reg
    By coxstevuk1973 in forum Vectra C / Signum Troubleshooting
    Last Post: 5th January 2010, 21:16
  3. Help, my Heater Has stopped working
    By nessie455 in forum Vectra C / Signum Troubleshooting
    Last Post: 1st January 2010, 18:54
  4. heater stopped working
    By vectragsi3.2 in forum Vectra C / Signum Car Chat
    Last Post: 13th February 2009, 07:56
  5. Heater blower has stopped working
    By Dave1971 in forum Electrical & ICE (including SatNav)
    Last Post: 3rd September 2008, 12:55
heaters pick when to work vectra c
where is Walsall Insignia fuse located for a heater
were is the fuse for heater blower in a vectra c
