Thread: Sticky revs
    Apr 2009
    inverkip
    confused Sticky revs
    Can anyone advise please. I have a vectra 1.9 cdti sri 150 nav which has developed a problem with the revs. Car is running fine but if i hard accelerate as soon as i hit 4,000 rpm the cars shudders. Initially it would pass through but yesterday is stopped accelerating at this point until i changed gear. It feels as if it is hitting a rev limiter. It is still doing the top speeds in 5th and 6th. As you can guess i am not very mechanically minded. The car did have its EGR valve replaced 3 months ago could this have caused an underlying problem.?
    Are you VXR Enough
    13 Post(s)
    Engine : 6.0 V8 Thunder
    sounds like you may have a split in one of the turbo pipes does the spanner light come on?
    Apr 2009
    inverkip
    Hello. I have no spanner light on . Car feels if running fine apart from hitting 4,000 rpm. gave it a run and was hitting ton plus in 5th and 6th.
    Are you VXR Enough
    13 Post(s)
    check your turbo pipes bud make sure there all tight and no splits
    Apr 2009
    inverkip
    cheers.
    update. just took car for run and had problem in 1st 2nd and 3rd gears only. On way back however car accelerated through all gears without a problem. Could it be dirt?
    Middlesex
    Trim : SRI
    Engine : CDTI 150 (Z19 DTH)
    Mileage : 100k
    sounds like the 3rd injector wiring issue to me mate.
    Are you VXR Enough
    13 Post(s)
    yep i agree
    Apr 2009
    inverkip
    I have heard a little about this but not much. I was under the impression that if this happens you lose all power and go into safe mode. I am not getting this. Car started running fine again. Seems to be better once running at normal temp.?
  1. Sticky oil?
    By spikeyboi33 in forum Vectra C / Signum Car Chat
    Last Post: 29th January 2013, 21:42
  2. Sticky clutch?
    By arry oudini in forum Engine & Drivetrain
    Last Post: 12th April 2012, 21:28
  3. Sticky Weights
    By s1nglef1sh in forum Suspension, Wheels & Brakes
    Last Post: 14th April 2009, 19:39
  4. Sticky Sub
    By parapaul in forum Electrical & ICE (including SatNav)
    Last Post: 1st November 2006, 03:28
