Thread: the tank ran dry
    Sep 2009
    middlesbrough
    Default the tank ran dry
    we have just bought a 150cdti sri, the car ran out of deisel on my g/f, the little orange car with the spanner through it flashed up and it cut out, i filled it with deisel and got it started again, the car is running fine but when you first put the key on ignition 2 the little orange car with spanner comes on momentarily then goes off, it didnt used to to that, will it have stored a fault that needs clearing or will it have pulled some water through the deisel filter and will it need replacing, does this light normally come on if you run out of deisel, cheers in adavnce
    Quote Originally Posted by durham4416 View Post
    Check your owners handbook, as there are three different types of this
    There is the EMS light which comes on when you put the key in the ignition, along with the ABS light (and in some models other warning lights)
    Once the EMS has checked they are working they go out
    There is the "near service" which appears in the display within and under the rev counter
    This looks like a car with a big spanner
    It appears briefly on startup
    There is the "due service now" which also appears in the display within and under the rev count
    This looks like a BIGGER spanner
    It appears during startup and stays for some time
    I would be more concerned if the EMS warning light comes on or flashes during normal driving
    This suggests a sensor has failed
    Equally, if you are near to running out of fuel the low warning tank light should come on at 7 litres and start flashing at 5 litres, and if you have the driver info centre there will be a range displayed for what is left in the tank
    In a diesel, NEVER run out of fuel
    The danger is not water but air, the system may now need bleeding to remove all the air
    However, if you take the car for a good blast of 70mph for at least 100 miles then it should be OK
    Administrator plasma's Avatar
    On the Forum
    368 Post(s)
    Engine : 150
    Mileage : 74000
    Did this when my car was only just out of the dealers from new... Spanner light came on when i ran out of diesel... Went out on its own after a good 30 or so key turns... So unless you fancy shelling out £40+ at a garage or dealers leave it for the week and see if it then resets itself, or you can cheat and disconnect the battery for 20mins...
    Regular Member robk6112's Avatar
    Halifax
    Yeah mine did the same too. It still comes on now a week later- my range showed 4 miles left when it ran out. I think my tuning box sends incorrect info to the fuel computer?
    May 2006
    scotland
    It will for sure stop doing it within a month of normal driving if it is a stored fault code that is no longer active.
    Trust me, I am a doctor.
    West
    As above... although i'm not a doctor lmao...
    Sep 2009
    middlesbrough
    cheers everyone thats alot of help, ill just wait till it goes off.
    Halifax
    mines gone off this morning- 9 days later
    Regular Member tangoman's Avatar
    Berinsfield,Oxford
    Vehicle : VXR Estate
    Trim : VXR
    Engine : 2800
    Mileage : 3000
    Not sure what others think, but I would advise you get the filter replaced.
    Regular Member deanos's Avatar
    UK
    Vehicle : Insignia
    Engine : 2.0
    Year : 2011
    Those little code readers off Ebay will clear the light if it gets on your tits, about £20 a pop
  1. oil catch tank
    By spidermonkey in forum Diesel Engine related
    Last Post: 6th June 2012, 11:04
  2. miles per tank
    By neilybhoy1888 in forum Vectra C / Signum Car Chat
    Last Post: 24th January 2011, 12:49
  3. What MPG on first tank
    By Casa1862 in forum Insignia car chat
    Last Post: 20th October 2010, 21:35
  4. Oil Catch Tank
    By JSYSH466Y in forum Petrol Engine related
    Last Post: 28th February 2009, 12:11
  5. Coolant tank
    By John2360 in forum Vectra C / Signum Car Chat
    Last Post: 25th January 2009, 14:09
