Thread: CD Player making loud noises and taking ages to play CD
    Regular Member baz_rochdale's Avatar
    Sep 2009
    Rochdale (Lancs)
    Engine : 1.9Cdti
    Mileage : 118000
    Default CD Player making loud noises and taking ages to play CD
    Afternoon guys. A few days ago when ejecting a cd the unit started making a loud clicking noise then stopped. It did it a few times after that but now when i turn the unit on it makes this noise or when ejecting a CD EVERY TIME now and its doing my head in. it will play a cd but you have to wait for it to stop having a paddy first.
    Any ideas on what it could be before it see's my steel toe capped boots!!
    Cheers.
    Mar 2007
    North East
    The radio model wouldn't go amiss.
    WGAF#5
    if its a multchanger unit i suspect the gear wheels are struggling to return the disc to the magazine - a strip and regrease of the associated cog wheels should help - before they wear and self destruct
    Full Member Robsey's Avatar
    North East Cheshire
    23 Post(s)
    Trim : Energy
    Mileage : 131,000
    As said above...can you please advise which radio / head-unit you are talking about.
    On very early cd players it is not un-common for the cd player to jam up a little causing the ejection mechanism to churn and clatter in a bid to spit out a stuck disk.
    And also there is the multi changer units that can stick a bit...
    either way either the mechanism or cd is getting caught up.
    It will be a mechanism alignment or lubrication issue
    Regular Member mikesri2.2's Avatar
    Jun 2009
    cheshire
    same prob here i have cdr2005
    still not found problem
    so if anyone got a answer would be grateful
    Sep 2009
    Rochdale (Lancs)
    Engine : 1.9Cdti
    Mileage : 118000
    Thats the unit i have. CDR 2005. its getting worse now. i wouldnt mine replacing it for another more updated Vauxhall unit but i'm told the new ones wont go in. i'm after the Mulit changer unit. or if it will fit. the CD30 i believe its called.
    WGAF#5
    Quote Originally Posted by baz_rochdale View Post
    cd30 is from a fully multiplexed model - it wont work
    strip and grease the gear cogs on yours with a very light lithium grease - will do wonders and save you a fortune
    Sep 2009
    Rochdale (Lancs)
    Engine : 1.9Cdti
    Mileage : 118000
    well i've only had the car just over a month and blagged 6 month warrenty out of the fella. so i'll look into if i can get it replaced. if not i'll do what you said deztroyer!
    Thanks for the help!!!
  1. Old not new but been ages
    By Jatie in forum Introduce yourself.
    Last Post: 12th November 2011, 18:40
  2. Handbrake making loud plastic/creaking noise
    By marky2027 in forum Vectra C / Signum Car Chat
    Last Post: 27th October 2010, 18:29
  3. loud clicking noises from behind heating pannel
    By 9tjc in forum Vectra C / Signum Car Chat
    Last Post: 30th November 2009, 09:43
  4. Should have done this ages ago.
    By Voxer in forum Quick Photo Album
    Last Post: 1st June 2009, 10:27
  5. MP3 player, play lists
    By Mark in forum Electrical & ICE (including SatNav)
    Last Post: 12th February 2007, 08:03
