Thread: side lights
    Aug 2009
    n ireland
    Default side lights
    just bought a 2002 2.0 dti vectra and have a small problem the front passengers side light will not work i have tried the bulb and tested it and there is no power going to it ,so removed the main plug on the back of the headlight and again no power ,checked all fuses in the 3 fuse boxes and all ok and strangely the same side front indicator has stopped working aswell and ideas what could be wrong ,the main beam and dip beam work fine ,the main plug is clean and dry but just is,nt getting any power to the both circuits, i removed the main fuse box and battery and cleaned up any earth wires i could find so now i have run out of ideas any help appreciated dwaine
    Aug 2009
    n ireland
    anyone
    Aug 2009
    n ireland
    if i say please maybe another thing i just seen it does not put up a fault that either bulb is,nt working but does on the other side when i removed the bulb could this be the fault ,does anybody no how the car checks the lights?? is there a box or ecu type thing anywhere that i could change?? come on someone give me advice good or bad does anyone have a link or no which fuses deal with the front side lights + indicator??wiring diagram
    WGAF#5
    just as a matter of interest - have you attempted to remove the opposite headlight and plug it in to see if that one works on the opposite connector - it may help rule out wiring or the lamp unit itself
    regards
    Dez
    Aug 2009
    n ireland
    thanks for the reply but as said i have tested with a electrical tester and there is no power going to it apart from the (main beam-dip beam) + what i assume is the test circult for bulb check ,only come one when turn on key so it must be to do with that , any other ideas about where or how the car self checks the lights??i think this is where the problem is possibly because as said it is,nt reporting a bulb fault which is strange
  1. side lights and number plate lights
    By antowens in forum Electrical & ICE (including SatNav)
    Last Post: 13th September 2012, 19:59
  2. Led Side Lights Fitted & 2 Rear Fog Lights
    By wardy23 in forum Electrical & ICE (including SatNav)
    Last Post: 12th March 2012, 23:16
  3. led dash lights and side light running lights
    By fjaimo10 in forum Vectra C / Signum Car Chat
    Last Post: 9th February 2012, 21:21
  4. Brighter Lights for side lights, Vectra SRI150
    By 150_SRI in forum Vectra C / Signum Car Chat
    Last Post: 13th July 2011, 23:50
  5. Philips bluevision h7 head lights & side lights brand new
    By davidlewis24 in forum Parts for sale
    Last Post: 19th March 2009, 22:42
