Thread: vectra b traction control
    Regular Member denzilbud's Avatar
    cambridge
    Default vectra b traction control
    hi all wonderd if someone could help my brother inlaw has just bought a vec b 2.2 but the traction control keeps flickering on and of what could be causing this is it something to do with the speed sensors.please help as i found the car for him and feel guilty that somethings gone wrong after only 2 days of ownership
    Birmingham
    Is it the switchable TC with the button in the dash-if so, could it just be a dodgy button/swicth?
    Bye bye Vec B
    - Hello Siggy!
    cambridge
    no mate its the one with no button im thinking its the abs sensors just wanted someone in the know to tell me the same
    The later vectra B (facelift) did not have a switch
    Therefore it will be the warning light, showing it is active
    The next step will be to test it to see if it is actually working
    Take the car to a suitable location (such as an empty car park or road away from residents), with a dry well maintained road surface, put the front windows down, and switch the radio off
    Test 1 :
    With the maximum amount of power accelerate harsh up to about 20mph in a straight line, then make a full emergency brake application
    There should be a retardation of the fuel and the TC warning light should flash during this entire operation
    Test 2 :
    With the car in 2nd gear, at about 20mph
    Pull the car sharply left or right AND apply full power, putting the car into one complete circle, and after completing the circle make a full emergency brake application
    Unlike above, there will be no retarfation of the fuel, instead the TC warning light should flash during this entire operation
    In this case it is applying one of the rear brakes only (opposite to the direciton of travel) so as to prevent understeer
    With the windows down you should not hear any tyre scream
    If you do then you should be able to work out if one or more of the ABS sensors is not working, as that tyre will be making noise
    In the earlier Vectra B the TC was switchable, and the test could be repeated both with and without TC; quiet and noisey respectively!
    Regular Member rushy's Avatar
    Vehicle : SRi
    Engine : Z22SE (2.2 Petrol)
    Mileage : 137000
    Test 2 :
    That's ESP not TC, I didn't know the Vec B had that fitted even as a cost option? TC works off the driven wheels only.
    Not on the Vectra B and its the same on the Vectra C
    The Traction Control monitors all four ABS sensors
    There are two functions; retard fuel and brake application
    With regard to brake application the TC has to have access to all four brakes to ensure safety and stability during application
    If only the front brakes were applied then the car would instantly go into understeer due to the loss of traction at the front
    This is also one reason why cars with TC tend to go through rear brakes faster than front brakes
    ESP works one stage further by applying the appropriate brakes together (whereas TC only applies ONE brake)
    This often results in a driver feeling a snatch from the rear of the vehicle during understeer as the car applies TC to the relevant brake at the rear and also hammering the opposite front brake
    The reaction is so much faster than TC alone
  1. My Vectra and traction control in the snow
    By pipamish in forum Vectra C / Signum Car Chat
    Last Post: 22nd January 2013, 10:14
  2. Traction Control Switch on Vectra C
    By NickT in forum Vectra C / Signum Car Chat
    Last Post: 1st February 2011, 20:50
  3. Traction control switch vectra c
    By bobby-tupper in forum Vectra C / Signum Car Chat
    Last Post: 27th November 2008, 22:53
  4. Vectra C Traction Control Switch
    Last Post: 23rd November 2008, 20:47
  5. vectra c turbo traction control
    By B16VJB in forum Vectra C / Signum Car Chat
    Last Post: 19th June 2006, 13:30
did vectra b have TC
vectra traction control flicker
traction control opel vectra b
tc opel vectra b
pecka salona kak snatj trubki opel vectra b
how do you know traction control is off on vectra b
kak snatj kreslo vectra c
