Results 1 to 10 of 14
Thread: Whistle from Turbo
    Sep 2009
    STAFFORDSHIRE
    Default Whistle from Turbo
    Hi
    My 1.9CDTI [150] Vectra has developed a 'whistle' at low revs <2000rpm
    It is noticeably worse when cold.
    Had it checked at vx dealers who confirm it is coming from the Turbo.
    My question are :
    How commom is this whistleing ?
    Is it something I should worry about ?
    Any solutions on how to resolve ?
    Is it an indication that the Turbo is about to fail ?
    Is a Turbo easy to replace or is it a garage jobbie ?
    How much to replace a Turbo ?
    Sorry for the 1001 questions.
    Thanks in advance for your help / advice
    Jason.
    Cambridgeshire
    Turbo whistle is normal. It means it's working and spooling up.
    It's a good sound to hear mate, sporty
    Nothing wrong as long as you are still getting the power...
    Regular Member exitusletalis's Avatar
    Helsinki
    If you dont have a sports panel- or conefilter and you still hear the whistle, the turbo might be coming to it's end.
    Cambridgeshire
    Quote Originally Posted by exitusletalis View Post
    Hmm...how is that? The turbo will make a noise because it's the noise of the air being forced through (whistling). Mine has been doing it since I bought it on 60k, it is now on 85k and it's fine....
    West
    As above matey... unless you have a drop in power or excessive smoke, nothing to worry about
    Quote Originally Posted by VX150-VECSRI View Post
    Apart from that, did they advise it was normal, something to keep your eye on, or an early sign of main bearing failure?
    Under 2000rpm it is rare to hear the turbo, unless you have the windows down and radio off
    Regular Member m111kan's Avatar
    Liverpool & Norfolk
    Mines only done 29k & has whistled since i bought it at 17k. No problems for me
    Regular Member John C S's Avatar
    May 2007
    Gangsta crossover on the drive? Check
    Some do and some don't whistle.
    It is all dependent on the trueness of the spindle on the bearings more than anything.
    Also they get quieter with time if all is well!
    I've ran a Citroen TD from 0-102,000 miles and a Fiat Ducato van from 0-150000 miles and both turbos quietened their whistles.
    All I would say is that it is unusual that yours has just started whistling.
    Jul 2009
    barnsley,yorkshire,GB
    Engine : 20 Dti
    as john says some do some don't it all depends ao the engineering tolerances,we run allmost one hundred vehicles mostly turbo's and as said do's and don'ts
    Jul 2009
    Engine : 20 Dti
    just a thought have you checked your exhaust manifold gasket,vx upgraded there gaskets to a multi layer gasket to cure this problem.can't remember what year though
  1. CDTI Turbo whistle
    By rob10 in forum Diesel Engine related
    Last Post: 7th August 2012, 20:16
  2. turbo whistle
    By Al 22 dti in forum The 'Off Topic' room
    Last Post: 19th June 2011, 18:56
  3. cdti 150 turbo whistle
    By spurty3030 in forum Engine & Drivetrain
    Last Post: 15th June 2011, 19:25
  4. 1.9 cdti turbo whistle?
    By Dom_cdti in forum Engine & Drivetrain
    Last Post: 3rd March 2009, 19:03
  5. Turbo Whistle Question
    By simonturner1975 in forum Engine & Drivetrain
    Last Post: 14th November 2008, 15:06
