Page 1 of 4 123 ... LastLast
Results 1 to 10 of 39
Thread: help needed vectra 30cdti 2005
    Regular Member 30ltr nutter's Avatar
    dunstable
    Default help needed vectra 30cdti 2005
    hi i need help from any one with a pre face lift 30cdti i need some continuity readings from the fuel injectors i need some one to messure the top 2 pins in the injector socket on the injector not the loom. i need to now what reading u get and weather the reading is constant or shows for a second and disapears i am trying to work out weather i need 4 or 2 injectors i would be greatfull to any one that can help me many thanks in advance.
    Regular Member Celes's Avatar
    Slovenia, Koper
    Vehicle : Opel Signum
    Trim : Sport
    Engine : 3.0 CDTI
    Year : 12/03
    I'm not sure what you're on about here mate
    There probably won't be any values showing, beucause the injector will have to be unplugged for the test.
    dunstable
    hi that is correct u need to unplug the injector and take the readings from the injector socket on top of the injector not the plug i am trying to work out weather the solonid valves on the injectors are faulty or not .
    dunstable
    help any body
    Any pics as to where they are? Can you not compare them to your others or are all 6 suspect?
    dunstable
    hi big sig i suspect i have 2 injectors that are faulty if u look at the rocker covers there are three injectors sticking out of the top of the covers one at each end and one in the centre and each one has a electrical plug connected to it . if u unplug the plug from the injector with the ignition off u will see 4 electrical pins inside the injector socket i need to now what reading u get if u test the continuity between the top 2 pins and weather the reading is constant or disapears straight away .so i can comfirm weather i need 4 injectors or just 2 the way the car pulls when driving i suspect i need only 2 i brought some off flee bay but they were no good and made the car worse many thanks
    I will see if I can do it for you tomorrow, fingers crossed i will remember to bring my multimeter home from work!
    dunstable
    cheers big sig if i dont reply its because i am away for the weekend many thanks
    Slovenia, Koper
    Trim : Sport
    Engine : 3.0 CDTI
    Year : 12/03
    Quote Originally Posted by 30ltr nutter View Post
    Where did you buy the injectors mate? I bought 6 from vauxcentre on ebay. I hope I didn't get the faulty ones you got first
    dunstable
    hi i got them from the same place and i took three back as they were faulty if u brought 6 then its possible they came out of a different car the ones i had came out of two different cars so i have a mixture of my origonal injectors and the rest came from them . and two of the injectors give different readings from the solonids on the injectors so i need to confirm which ones are faulty 2 or 4 of them but i suspect its the 2 that are faulty what does your car do and if u changed the injectors has it made it better
  1. Rubber seal needed for dab Aerial on a 2005 vectra elite.
    By hibbski in forum Bodywork & Interior
    Last Post: 11th June 2012, 19:40
  2. 30cdti bhp
    By 30ltr nutter in forum Engine & Drivetrain
    Last Post: 7th June 2008, 14:11
