Results 1 to 10 of 18
Thread: Engine management Light
    Sep 2009
    uk
    confused Engine management Light
    Hello i am not sure how to use forums properly so i hope i am doing everything right here.
    i have just bought a vaxhaull vectra 16v 1.8 S reg but there seems to be a problem with the engine management light. as soon as you turn the ignition key the light comes on and stays on. i also know little about cars only the basics but im willing to try anything new. is there a way to reset the engine management system or check to see what is causing it to stay on without taking it to a garage as im now pennyless. i'd really appreciate any support i can get. thank you
    5 Post(s)
    Quote Originally Posted by squeeky View Post
    Fixing the problem is generally the only way. Once the fault is fixed the light should self extinguish.
    Depending on the age of the car, you might be able to do the paperclip trick - http://www.topbuzz.co.uk/info/fault_...ault_codes.htm
    or I've heard that the pedal trick may well work on Vectra-B's that won't let you do the paperclip trick.
    http://www.vectra-c.com/forum/showthread.php?t=81742
    Sep 2009
    uk
    thank you Big Dave tomorrow morning i will go out and try those methods. i 'really' appreciate the help. from what the guy told me he put a new cam belt on and since then its the light comes on and stays on. when the car is ideling it does feel like the car is rocking back and forth a little but i think that might also be part of the same problem. i will try first thing in the morning and post back. thanks once again much appreciated
    Jul 2009
    sussex
    yeah the paper clip will work for you. the plug is under the centre console. 5 min job!
    Sep 2009
    uk
    how can i tell what type of system i have ie. Motronic or GM-Multec fuel system orSimtec 56.0 or 56.1 fuel system or Simtec 56.5 fuel system? i know nothing about this. all i know is that its a 1998 Vectra Arctic 16v and its a 1799 cc
    how can i find out what type of fuel system i have? by the way it is petrol that much i do know. thanks
    Sep 2009
    uk
    Quote Originally Posted by johnsav View Post
    how do i get to the center console? i have no service manual for the car and i am not sure how i get to the plug without breaking something. sorry for my stupidness but i was always told, if in doubt ask so here i am asking
    thanks
    5 Post(s)
    The diagnostic plug is under a removable cover beneath the handbrake lever.
    Sep 2009
    uk
    ah found it, i see this one http://www.topbuzz.co.uk/info/fault_codes/pic007.htm a black socket with 16 holes so im gonna go try that out now. btw the pedal trick didnt work, tried it a few times but no luck. will post back soon.
    p.s. ive also disabled the battery for 15 - 30 mins to see if it helps. thanks
    Sep 2009
    uk
    ok done the test and these are the results below...
    10 flashed short rest
    3 flashes shert rest
    4 flashes short rest
    10 flashes loooong rest
    then does the same squence all over again but i cant see to find the the fault code listed anywhere?
    Sep 2009
    uk
    i figure the fault code is 0340 camshaft sensor.
    the guy i bought it from did say it only come on since he fitted a new timing belt so im wondering if he forgot to connect the wires to the sensor.
    im not sure where to find the sensor so i guess i got some more forum searching do do before i ask for anymore help.
    Massive thanks Big Dave and johnsav for the support its much appreciated. oh and one last question before i go off searching... if i didnt bother sorting it out would it do the car any harm? thank
    By Shadrack in forum Troubleshooting
  2. Replies: 17
    Last Post: 16th August 2012, 10:07
  3. EGR Valve, Engine Management Light & Spanner Light
    By guygreen in forum Engine & Drivetrain
    Last Post: 12th December 2010, 20:09
  4. No throttle, traction control light, engine management light
    By si260188 in forum Engine & Drivetrain
    Last Post: 9th May 2010, 21:45
  5. Replies: 3
    Last Post: 28th April 2009, 19:49
