Results 1 to 3 of 3
Thread: Knocking noise...
    Regular Member Gripper's Avatar
    Middle Wallop Andover
    Default Knocking noise...
    Just had a witter tow bar fitted to my CDTi and it is knocking against the side of my after market back box. Has any one had this problem before, if so what was the solution?
    I was thinking of going to an exhaust place, like ATS, and gettin a longer rubber hanger to drop the back box by about 15mm. Would that be a good idea. Help would be greatly appreciated. Thanks.
    Regular Member shippers's Avatar
    Jun 2007
    driffield
    I had a problem like this on my old vec b and what I did was stiffen up the original rubber mount with a couple of good thick zip ties around them,If you put longer mounts on will it not swing more and still knock on your back box?
    Cheers for that Shippers, I will try the zip tie, (plasty cuff) route. Never thought of stiffening what was already there.
  1. knocking noise
    By 150cdi in forum Suspension, Wheels & Brakes
    Last Post: 26th July 2010, 19:20
  2. help with me knocking noise please....
    By paul.sessions in forum Suspension, Wheels & Brakes
    Last Post: 15th April 2010, 21:00
  3. knocking noise
    By Morephun in forum Suspension, Wheels & Brakes
    Last Post: 22nd December 2008, 18:16
  4. Knocking Noise?
    By akeem in forum Suspension, Wheels & Brakes
    Last Post: 23rd March 2008, 19:17
  5. 1.8ls knocking noise-help!
    By bri.gsi in forum Engine & Drivetrain
    Last Post: 17th January 2008, 18:25
