Results 1 to 3 of 3
Thread: Reversing lights getting brighter with engine speed/revs?
    Regular Member v6vc's Avatar
    Jul 2009
    Planet Earth
    Vehicle : Vectra & Signum
    Trim : GSi & Design
    Engine : 3.2 V6 & 2.8 V6 T
    Year : 02/07
    Default Reversing lights getting brighter with engine speed/revs?
    Hi guys
    I've noticed the last few times when i've been reversing that my reversing lights increase in brightness with engine speed.
    I'm not brilliant with all this stuff but from what I know, sounds like alternator or a bad earth? Sound right?
    I have no battery light on so guessing its not the alternator so what earths should I be checking?
    Also, would a bad earth be the cause of an intermittent starting problem?
    Cheers guys
    P.S It's a GSI if that makes any difference.
    Mileage : 000
    I think you will find thery all do it. The electro/numatic (or whatever you call it) power steering will take a good drain on the altornator on slow revs. Have you noticed the "info" screen go dim when you turn the wheels at low revs, you will even see the headlights go dim too. So you might not have a problem. But best to put a meter on the battery to check it.
    Jul 2009
    Planet Earth
    Trim : GSi & Design
    Year : 02/07
    Cheers Ed
    I've thought along the same lines as that too but it does it even when stationary and not turning the wheels. Everything else that is 'lit' doesn't have the same noticable problem.
    Will try to to find someone with a battery meter .......
  1. Brighter Lights for side lights, Vectra SRI150
    By 150_SRI in forum Vectra C / Signum Car Chat
    Last Post: 13th July 2011, 23:50
  2. Clunking from O/S front at slow speed and reversing?
    By stephenmessy in forum Suspension, Wheels & Brakes
    Last Post: 19th January 2010, 20:59
  3. Revs/Speed 2.2dti Sri
    By TinFish in forum Diesel Engine related
    Last Post: 27th November 2008, 13:36
  4. speed and revs in gear 2
    By Mike57 in forum Vectra C / Signum Car Chat
    Last Post: 20th October 2006, 11:15
  5. reversing lights
    By ed taylor in forum General Chat
    Last Post: 22nd July 2006, 15:48
intermittent starting problems with vectra c 3.2 v6 www.vectra-c.com
