Thread: Will SAAB 9-5 brakes fit?
    Forum Moderator John LE's Avatar
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    Default Will SAAB 9-5 brakes fit?
    I have come accross a set of calipers from a 2007 plate Saab 9-5. And i think they are the 314 set up. Will they fit or is it only the 9-3 brakes that will fit
    Regular Member Telly Addict's Avatar
    Sep 2009
    Fife
    Vehicle : BMW e92 335d
    Trim : M Sport
    Engine : 3.0 TT
    According to EBC Brakes Direct they are 308mm.
    Forfar, Scotland
    Trim : LE/VXR
    Year : 13/07
    Mmmmm interesting, anyone know if they will still fit??
    Sep 2009
    Fife
    Trim : M Sport
    Engine : 3.0 TT
    I believe they will if you have the calipers and the carriers, just that most people hold out for the 314mm jobbies.
    Regular Member Jezzy's Avatar
    S.E
    No, they won't fit, or rather they have nothing more in common with Vec-C brakes than any other random car on the road. The Vec-C and Saab 9-3 share the same chassis, hence why many components such as brakes and engines are shared. As an aside, the 314mm Vec-C/9-3 brakes have more in common with the 320mm brakes on the Ford Focus ST (the 225bhp Mk II model) as the calipers for the ST and Vec-C are both made by ATE and the calipers are 99% identical to look at. The 9-5 brakes will have little in common with these.
    Sep 2009
    Fife
    Trim : M Sport
    Engine : 3.0 TT
    Are you sure? Just that there are a few Vx motors with 308mm discs and saab are a GM company after all. Not saying I know, just that it seems more likely than not.
    Regular Member rushy's Avatar
    Vehicle : SRi
    Engine : Z22SE (2.2 Petrol)
    Mileage : 110000
    308's are Vec B. 285, 302 314 are vec c and I think its 345 are Vec VXR
    S.E
    The Saab 9-5 and the Vec-B were developed together; so if you've got a Vec-B the 308's might fit (if you had the 5-stud hub), but for a Vec-C, it's a no-no.
    Sep 2009
    Fife
    Trim : M Sport
    Engine : 3.0 TT
    Ah...gotcha!
    Leicester
    Quote Originally Posted by Telly Addict View Post
    All 9-5 components are different.
    308's were originally fitted to Astra and Zafira Turbo's, the Vec B had adapted carriers for the facelift 2.6 GSi to have 308's.
  1. saab brakes ?
    By peadar in forum Suspension, Wheels & Brakes
    Last Post: 8th August 2009, 18:03
  2. saab brakes
    By G.T.S in forum Handling & Braking
    Last Post: 2nd April 2009, 20:18
  3. Saab brakes
    By Danwells72 in forum Handling & Braking
    Last Post: 4th July 2008, 19:20
  4. saab brakes
    By kenny1zero in forum Vectra C / Signum Car Chat
    Last Post: 24th June 2008, 07:28
saab 9-5 brakes same as vectra
