Results 1 to 10 of 13
Thread: Set alarm
    Sep 2009
    Glasgow
    Question Set alarm
    Just a quick on , no user manual for my vectra 1.9 cdti sri 150, seems stupid how do i set alarm. i press fob to lock then press again to dead lock as i do with every car, is the alarm set on the first press or is there a a set way to turn it on.
    Are you VXR Enough
    13 Post(s)
    Engine : 6.0 V8 Thunder
    the alarm is set as soon as you lock the doors bud
    Sep 2009
    Glasgow
    cheers.
    Full Member Robsey's Avatar
    North East Cheshire
    22 Post(s)
    Trim : Energy
    Mileage : 131,000
    Doors lock on first press
    Then dead-lock and initiate alarm on the second press
    Unless you have reprogrammed the key to fully lock etc on single key press.
    I believe this is right, but welcome any corrections...I always double press anyway, unless I am to-ing and fro-ing from the car.
    11 Post(s)
    Quote Originally Posted by Robsey View Post
    Then dead-lock and initiate alarm on the second press.
    Alarm is on with first press. You should see the flashing LED on the dash when it's armed.
    Reason for it arming on first press is the auto locking feature if you accidentally unlock the door while walking away from the car and don't re-enter the car within 30 seconds. The auto locking will lock the car for you and set the alarm (the deadlocks won't be set though)
    The car should actually lock itself, with the key out of the ignition, even if you forget to do so
    Try it, just be careful the car doesn't lock one of your keys inside!
    However, I find it annoying sometimes as it usually happens when I am in the middle of loading the boot up with luggage!
    Full Member Big Sig's Avatar
    Hmmm, are you sure as I am fairly sure mine doesn't!
    Regular Member purple170503's Avatar
    kent
    If theres a way of setting that up it would be good, I've forgotten to lock my car before and in the morning was still unlocked so fairly certain it doesn't do that on my model anyway.
    Nottinghamshire
    The car will re-lock itself (but not deadlock) if you unlock it but then don't open anything. I think it assumes you didn't mean to unlock it in the first place - knocked the button on the key or something.
    If you unlock only the boot, then open it then close it, it will lock itself after some time.
    The alarm comes on with the first press of the lock key - you will see the alarm light come on for 10 seconds then start flashing. This means that there is no way you can lock your car but not have the alarm on -annoying when you are on a ferry.
    My car is a 2003/52 and it seems that some of these things changed over time, so the only way to see what works on your car is to try it and see.
    11 Post(s)
    Neither does mine, apart from when unlocking it and not opening a door within 30 seconds.
  1. Car alarm keeps going off
    By si_hoss in forum Vectra C / Signum Car Chat
    Last Post: 29th April 2015, 18:37
  2. Alarm keeps going off?!
    By Ben Chiles in forum Electrical & ICE (including SatNav)
    Last Post: 17th April 2012, 22:26
  3. Alarm led?
    By Vectra Karl in forum Electrical & ICE (including SatNav)
    Last Post: 9th January 2012, 22:43
  4. alarm keeps going off
    By the fisherman in forum Electrical & ICE (including SatNav)
    Last Post: 25th July 2011, 01:22
  5. how do i get to my alarm??
    By bangty 1 in forum Vectra C / Signum Car Chat
    Last Post: 5th November 2010, 19:51
vectra c auto door locking of door not opened locking www.vectra-c.com
