Thread: Problem Car
    Regular Member Clugie's Avatar
    Jun 2009
    Liverpool
    Unhappy Problem Car
    Bin Driving the veccy home from london today everythin was fine, i got home had a rest, then had my normal monday night fotball so i went to pick some lads up an noticed that i had to keep my finger on the window button to make it go all the way down, anyone had problems like that before or do you know how to solve it? an the gear stick was an still is very hard to move into gear? any advice guys?? it will be much appreciated, thanks
    Full Member Robsey's Avatar
    North East Cheshire
    23 Post(s)
    Trim : Energy
    Mileage : 131,000
    Regarding the gear selection...only time I have had this problem has been with the clutch being worn or out of adjustment.
    The clutch is hydraulic so I would check that the fluid level is okay...other than this, I would hate to suggest the dual-mass fly-wheel.....(eeek!!)
    However check that nothing has dropped near any of the linkages for your gears....especially if you have worked under the bonnet recently.
    Regarding the windows, I believe that these can be reset on all models from 1987 to 2009 by simply holding the window closer button pressed in until the window is fully closed, then for a further three or four seconds.
    Job should be done....have you worked under the bonnet and cut battery power (removed battery lead(s) as this will require resetting of the windows as described...all windows may need to be done.
    Regular Member brifen's Avatar
    Fareham
    Vehicle : Vauxhall Signum 2.0 DTI (Irmscher)
    Trim : Elegance
    Engine : 2.0 DTI 100 bhp
    Not sure about the gearstick, but for the windows if you put the window fully down then fully up, once back in the fully up position press and hold the up button for atleast 3 seconds and this will return the window to auto up and auto down. Carry out the same for the other window/s.
    Bri.
    Jun 2009
    Liverpool
    Windows are now working, thanks for the advice, gettin the gear stick situation looked at next thursday, as thats the only time they have to fit me in
  1. Rear Signum Light problem problem - help
  3. 1 problem sorted and 1 more problem arises
    Last Post: 4th April 2011, 13:03
  4. Bit of a problem, Need Help
    By vectrasri-j in forum Vectra C / Signum Car Chat
    Last Post: 18th January 2010, 19:21
  5. Problem...? Vectra SXI...problem with starting after filling with fuel?
