Thread: PO341 Help
    worcs
    Default PO341 Help
    Vectra c Z2.2se I keep getting fault code P0341 which is Cam sensor.
    The engine appears to run OK any ideas where to look has the Heynes manual does not mention where i can find the cam sensor or even if it has one, any ideas?
    Thanks Martin
    Regular Member rushy's Avatar
    Vehicle : SRi
    Engine : Z22SE (2.2 Petrol)
    Mileage : 137000
    Have you asked over on the 2.2 forum mate, they'll be able to give you the definitive answer.
    worcs
    Not yet where is it
    Vehicle : SRi
    Mileage : 137000
    z22se.co.uk mate. As site dedicated to our engine, for tuning and general running issues.
    worcs
    Help have now replaced Crank sensor and coilpack still keep getting eml light with P0341 fault (Cam sensor) even though the Z22se doesn't have one.
    ANY IDEAS
    Martin
    Mar 2011
    Hmm
    Did you fix this mate im getting the same problems.
    worcs
    Hi Yes I did fix the fault.
    The fault started about a month after a service using genuine parts including changing the spark plugs. To try to fix I Replaced Coil Pack, Crank sensor , Then sent car to U/s stealer's you didn't have a clue and tried to sell me a £600 ECU with no guarantee of it fixing the problem Told them where to put the ECU!!!
    Finally found out that the Genuine Spark plugs were faulty, put another set in and all OK so replaced COIL PACK, CRANK SENSOR TECH 2 for no reason!!!!!!!!!!!!!!!!!!!!!!!!
    Mar 2011
    Hmm
    I Hope this does it!!! when i brought this i was told it started when the spark plugs were changed. sounds hopefull!!!
    thanks for the reply mate i will write back after changing plugs tomorrow.
    Mar 2011
    Hmm
    Spark plugs I owe you a beer mate! saved me a hefty bill a vaux! Thanks.
Opel P0341
vectra c 2.2 p0341 code
p0341 z22se
vauxhall insignia p0341
Vectra p0341
vectra c 2.2 petrol crank sensor site:www.vectra-c.com
