Results 1 to 3 of 3
Thread: Ok, I know.....
    Regular Member david.aka.judas's Avatar
    Suffolk
    Default Ok, I know.....
    I have a problem with the car...
    a broken re-circ gear, it clicks when you press the button to open the vent and I think at some point it was stuck closed, causing the car to steam up really bad.
    but...... why does the car click about 5 or 6 times even though no one's used it or gone near it?
    its done it about 3 times tonight between 6pm and now.
    what do I need to tell the warranty co?
    cheers if you can help.
    Mileage : 000
    Just tell them that the recirc servo motor is "broken". From what I can make out this "servo" works in the background most of the time without the drivers intervention. In other words when you switch off the ignition the servo "closes" the air vents, then when you open the door ( via the buttons on the key fob) the servo "opens" the vents.
    I sussed this out when mine packed up. If it wasn,t for the noise it makes when it is broken I would have not known it was working without my knowege. I at first wondered why mine had broken as I very rearly pressed the button on the heater panel for the recirc.
    Hope this all makes sence.
    Suffolk
    hi - that makes perfect sense and I appreciate your response - I shall tell them.
    cheers and I'll let you know how I get on.
