Thread: body control unit
    worcester
    Default body control unit
    Rear door on 2.0dti signum will not open, rear door module replaced with no change. All functions work with press of keys to open door ie. lights on etc except no motor whirl that opens the door. (It used to open to the first latch but now does not at open, which means at least I don't have to keep hitting the rear door to close it)
    Garage suspect "body control unit" faulty and needs replacing. Have been told this is main dealer problem and send the car for checking and fixing.
    Reading various threads the item is located under the glove box but have found nothing about how to replace it or the cost.
    help please
    Regular Member kenp's Avatar
    Kr. Hyllinge, Denmark
    Engine : 2.2 Direct
    its behind the kickpanel in the passengerside or near the fusebox i reacon.
    Full Member
    Bristol
    Yes it is dealer fit only using tech2.
    Regular Member paul wingnut's Avatar
    durham
    Vehicle : vectra sri 150
    Engine : 1900 cdti 150
    check wiring to door from b post for broken wire
    Feb 2006
    Dorset
    Door Modules need to be tech2 'd out and in for them to work.
    worcester
    Quick update.
    Car tech2 tested and door micro switch fault found, plus egr fault.(another thread)
    Funny thing today 13th the door has started to work and everything is back to normal, will let you know if that changes.
  1. Body control unit
    By clive.22 in forum Electrical & ICE (including SatNav)
    Last Post: 11th February 2013, 14:51
  2. Body Control Module
    By 1973andi in forum Electrical & ICE (including SatNav)
    Last Post: 26th May 2011, 23:24
  3. GSI Body Control Module?
    By 900ss in forum Electrical & ICE (including SatNav)
    Last Post: 22nd January 2009, 08:56
  4. where's the body control unit
    By mhvcbv in forum Electrical & ICE (including SatNav)
    Last Post: 25th October 2008, 21:53
  5. Body Control Module ?
    Last Post: 23rd July 2008, 18:39
vectra c body control module location
vectra c body control module location www.vectra-c.com
vectra c body control module faults
opel vectra c body control modul www.vectra-c.com
