Results 1 to 3 of 3
Thread: Crank Sensor location cdti 150
    Regular Member kirkyoke's Avatar
    South Yorkshire UK
    Default Crank Sensor location cdti 150
    Hi,
    Does anyone know where the crank sensor is on the 1.9cdti 150 please?
    Regards,
    Dave.
    Regular Member paul wingnut's Avatar
    durham
    Vehicle : vectra sri 150
    Engine : 1900 cdti 150
    its under the starter motor mate you need to get at it from underneath
    South Yorkshire UK
    Ok, thanks for the speedy reply paul, much appreciated
    Dave.
  1. Where is the crank sensor 1.9 cdti 8v
    By deanos in forum Vectra C / Signum Car Chat
    Last Post: 5th February 2013, 05:46
  2. Crank Sensor
    By GCusdin in forum Engine & Drivetrain
    Last Post: 13th December 2012, 12:13
  3. crank shaft sensor
    By dr1v3r in forum Electrical & ICE (including SatNav)
    Last Post: 3rd October 2012, 19:54
  4. P0340 - could it be crank sensor?
    By rich r in forum Engine & Drivetrain
    Last Post: 25th December 2011, 19:00
  5. Crank Sensor = Limp Mode??
    By si_hoss in forum Engine & Drivetrain
    Last Post: 1st December 2011, 21:20
vauxhall vectra 1.9 cdti crankshaft sensor location
vectra 1.9 cdti crank sensor location
z19dth crank sensor location
vectra cdti 150 crank sensor
astra 1.9 cdti crankshaft sensor location
vectra 1.9 cdti crankshaft sensor locationz19dth crank sensorcrankshaft sencor 1.9cdti vectravectra c 1.9 cdti crank senorcrank sensor location on astra 150signum cdti 150 crankshaft position sensorsignum cdti crankshaft sensorvectra c 1.9cdti where is crankshaft sensorastra cdti 150 crank sensor locationwhere is the crank sensor on a 1.9 cdti astracdti 150 crank sensor changevectra c 1.9 cdti crankshaft sensor locationcrankshaft sensor vauxhall astra 19cdti 2008vectra 07 crankshaft sensor signum 1.9 cdti crank sensorvectra c 2008 crank sensor locationvauxhall vectra c 1.9 cdti camshaft sensor locationsignum cdti 150 crank shaft sensorhow to test a 2008 1.9cdti astra crank sensor
