Thread: What can i possibly do next (150cdti)
    Regular Member kirkyoke's Avatar
    South Yorkshire UK
    Default What can i possibly do next (150cdti)
    Hi all,
    Having read a lot of posts regarding misfire on the vectra cdti's i still cannot cure this problem of mine .
    It all started approx 6 months ago, when pulling away from junctions, roundabouts etc, i get the occasional split second cough (would'nt say misfire) sometimes it does it every couple of miles then sometimes it will run a week without doing it!! It is fine if you boot it all the time!!
    Heres what has been done recently:
    New EGR Valve
    New manifold & swirl actuator,
    New Fuel Filter,
    New Air Filter,
    But still to no avail,
    Can the No.3 injector wire cause just a split second cough like this,
    No codes are present using the snap on solus pro & sykes pickavant acr4 G2 suite,
    My last resort is to send it to the dealers to see if they can find it using tech2 but i hate the idea of paying £60-£70 for them to say it could be this, could be that etc, (you know what i mean)
    Can the accelerator pedal sensor cause this as it always seems to be when the pedal is in a certain position!
    Seriously thinking of getting rid, but it's such a nice car except for this little hiccup now & again,
    There is a slight rattle from the Dual Mass flywheel (could this cause it??)
    Any help greatly appreciated!
    It is a 55 plate vectra cdti elite 150
    Thanks.
    Dave.
    Last edited by kirkyoke; 7th September 2009 at 16:45. Reason: forgot to add something
    Full Member Big Sig's Avatar
    If you haven't done the 3rd injection mod then do it. Its very cheap and well worth while as it could be the cause of your troubles.
    South Yorkshire UK
    Thanks for the reply Big Sig, will try it & keep you posted although i would have thought that moving the injector wire with the engine running would make it misfire but it does'nt,
    Cheers,
    Dave.
    Its the contacts that fail not the wire normally as it gets stretched. The mod is only about £20 so well worth it imo. Although cleaning the connections can be a quick and usually temp soloution.
    South Yorkshire UK
    No.3 injector wiring now done & guess what?? ....... it's still the same ... now totally baffled!! anybody any other ideas??
    Administrator plasma's Avatar
    On the Forum
    368 Post(s)
    Engine : 150
    Mileage : 74000
    Check the engine software version...? Think there was an upgrade for a problem similar to this. Contact your Vx dealer and get them to check...
    South Yorkshire UK
    ok thanks plasma, will give the robbing b******s! a ring, i'm getting fed up of spending on it now for such a ****potical fault, time for it to go i think!!
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Engine : 2.0 TDI 184PS
    Mileage : 40000
    Mines used to not so much cough but hesitate and judder at 2000rpm, and it turn out to be the Intercooler had split.
    It might not be the intercooler but a split hose?
    Gazza4
    South Yorkshire UK
    hi gazza, no judder or power problems just the intermittent cough every now & then, not enough to throw a code up i don't think (as much as i wish it would)
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Mileage : 40000
    Quote Originally Posted by kirkyoke View Post
    Thats how it started and was like that for a year, then after I cleaned the egr valve it progressively worse within a week.
    Gazza4
  1. hello from a new SRI 150cdti owner
    By nick_w in forum Introduce yourself.
    Last Post: 23rd October 2012, 08:38
  2. 150cdti EGR bypass.
    By mally in forum Diesel Engine related
    Last Post: 14th April 2011, 00:18
  3. 120?150cdti? or dti ?
    By m999mwb in forum Vectra C / Signum Car Chat
    Last Post: 11th April 2010, 00:36
  4. My 57 150cdti SRI nav
    By Barker.Vectra.Sri in forum Quick Photo Album
    Last Post: 20th December 2009, 22:46
  5. which is faster top end,150cdti facelift or 150cdti pre facelift?
    By andy d in forum Vectra C / Signum Car Chat
    Last Post: 30th January 2007, 00:43
